///M3 Forum
Old 01-02-2013, 06:55 PM   #21
Ballerbrian4u
My Ride: 2004 BMW m3
I got a alinement t some cheap tire shop for 40 dollars. And I think this problem started after that. I think. Could that be the problem??
Ballerbrian4u is offline   Reply With Quote
Old 01-02-2013, 07:28 PM   #22
0asis2007
My Ride: 2003 BMW E46 M3 SMG
Originally Posted by Ballerbrian4u View Post
I have done the soft reset many time. It did not help.
The SMG soft reset won't really help the "shudder from standstill" problem. Yours is a clutch-related issue, not an SMG gearbox-related issue as such.
This only happens when the car is fully warmed up. When it's cold the car is perfect. Where can I get the clutch software?
I'm UK-based, so couldn't really advise where you can get the software locally. I'm sure a US-based forum member will be able to tell you where best to source this software. The software you need is something like INPA, NCIS, DIS, etc.
But a clutch recalibration is something best left to someone who has some knowledge of what they're doing with the software. If you're new to it, there's a risk of messing things up.....
Do I go to the dealer to get the clutch recalibration software? How much dose it cost?
No, the dealer won't sell it to you. As I said above, source it locally. In the UK, you can pick up the software and necessary cable for around 30GBP.
Why dose it only happen when the car is hot?
Not sure why this is, but someone else may know?
Thanks for the explanation. I hope that when you change the clutch it will resolve the problem. Please let me know. Also how much dose it cost to get a new clutch? Can I get it resurfaced? Also is the clutch the only thing that needs to be replaced?
I honestly don't think a new clutch should be top of your list of solutions. Especially as your car is only 45k miles?!! Definitely try the above clutch recalibration first.
Originally Posted by voidopolis View Post
have you replaced the salmon relay yet? I'd do that as a first step before doing much else... is the dash SMG COG light on? is the car throwing any codes?
As I said above, this fault has little/nothing to do with your SMG gearbox directly. So the relay, the SMG cog light, etc are irrelevant here.
It is a clutch calibration issue!
Hope this helps!
0asis2007
2004 M3 SMG
TiAg/Black
0asis2007 is offline   Reply With Quote
Old 01-02-2013, 07:29 PM   #23
0asis2007
I doubt it!
0asis2007
2004 M3 SMG
TiAg/Black
Old 01-02-2013, 07:34 PM   #24
Ballerbrian4u
Repost
Old 01-03-2013, 03:05 AM   #25
Ballerbrian4u
You guys are really helpful and all this info is really appreciated!!!!! I really dont like doing anything my self so where can I get my clutch recalibrated ? Indi shop? Also should I update my smg software?
Old 01-04-2013, 02:05 AM   #26
xcar360
Past Site Sponsor
My Ride: BMW 318i
Maybe it's no sport mode.
xcar360 is offline   Reply With Quote
Old 01-04-2013, 10:42 PM   #27
Ballerbrian4u
Where an I get my clutch recalibrated? Will that solve my problem? How much dose it cost around?
Old 01-05-2013, 12:29 AM   #28
Vincent_m3
My Ride: 04 M3
Are you refering on smg calibration?
Vincent_m3 is offline   Reply With Quote
Old 01-05-2013, 02:29 AM   #29
Ballerbrian4u
Yes
Old 01-05-2013, 06:19 AM   #30
0asis2007
Yes
No, not quite.
I thought SMG calibration was something different to clutch calibration (biting point reset?)
0asis2007
2004 M3 SMG
TiAg/Black
Old 01-05-2013, 05:01 PM   #31
Ballerbrian4u
So do I need a clutch calibration or a smg calibation?
Old 01-05-2013, 10:06 PM   #32
Ballerbrian4u
Please help me guys!!!!
Old 01-05-2013, 10:31 PM   #33
0asis2007
Clutch.
Someone local to you must be able to help? Either try a good BMW specialist, or someone who knows how to use the diagnostic software.
And it's best done when the car is cold.
0asis2007
2004 M3 SMG
TiAg/Black
Old 01-06-2013, 10:40 PM   #34
Ballerbrian4u
Will this clutch calibration solve my problem 100%? Around How much dose it cost ? Thanks for the help!!!
Old 01-07-2013, 12:01 AM   #35
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
Ok if you own a SMG M3, you should always have at least 1 spare salmon relay in the car at all times. you can get the relay at any BMW dealership, but I would check around and get it at the lowest price (including shipping & tax).
Now to address your issue. Will a clutch adaptation learn-in fix your problem. Yes, if your problem is clutch engagement. Maybe or no if there are other issues. A SMG clutch should last in excess of 100k miles under normal usage. (now anything man made can fail at any given point in it's life span) Check your regional forum section for someone with a INPA/DIS/GT1 computer that is willing to do a clutch learn-in. You're going to need a heavy-duty battery charger also.
The cost will be based on the hourly rate of whomever is performing the work. A fanatic might charge you $60 and a dealership might charge you $250 ( all prices are guesses as I don't know what the person performing the work's hourly rate is and how long they perceive the work to take.)
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 01-07-2013, 12:16 AM   #36
armenhart
My Ride: 2005 E46 M3
Hey, first post ever, thought I'd give my 2 cents.
I drive a 2005 M3 SMG and I've been having this same shuddering problem. But mine has ~72000 and it shudders when it's both hot and cold. I took it to my mechanic (we are very good friends) and he said it needs a new clutch, but I can wait a little longer before changing it. He said it will cost about $1500. Not the greatest news, but I trust him. This could possibly be the same issue for you.
armenhart is offline   Reply With Quote
Old 01-07-2013, 01:43 AM   #37
turbo_f22_pilot
Usually a new clutch isn't needed. The clutch needs to be re-learned (adaptations). Sometimes it's the slave cylinder. Very seldom is it a damaged / worn out clutch until you're closer to 100k. But failure has happened before 100k.
Also, if he replaces the clutch, the relearn process has to be run after installation to ensure proper inital engagement.
Joy is future proof
CAR:
MODS:
BMWCCA NCC
Old 01-07-2013, 03:56 PM   #38
Ballerbrian4u
Thank you so much for such a great answer! Everything I needed to know.
Old 01-08-2013, 02:56 AM   #39
Ballerbrian4u
Sorry guys should I ask for a smg adaptation or a smg teach-in?
Old 01-08-2013, 09:32 AM   #40
$ilent ///M
My Ride: 03.5 M3 smg lsb
Ask for smg clutch teach in. this will let the computer know when the clutch is engaged. same as when you would drive a manual and feathering the clutch. The teach in will let the smg know how far the clutch is until full engagement. Where as the manual you can feel it and start pressing the accelerater
$ilent ///M is offline   Reply With Quote
