///M3 Forum
Old 01-08-2013, 09:44 AM   #41
choxor
My Ride: JDM
http://www.m3forum.net/m3forum/showthread.php?t=343511 Good information on the different SMG tests.
Old 01-20-2013, 02:17 AM   #42
Ballerbrian4u
My Ride: 2004 BMW m3
Does the car need to be connected to a power source when doing the adaptation?
Ballerbrian4u is offline   Reply With Quote
Old 01-20-2013, 11:33 AM   #43
$ilent ///M
My Ride: 03.5 M3 smg lsb
Yes you will need to have a suitable battery charger connected
$ilent ///M is offline   Reply With Quote
Old 01-22-2013, 01:49 AM   #44
Ballerbrian4u
How often does this need to be preformed?
Old 01-22-2013, 02:23 PM   #45
Ballerbrian4u
Anyone know how long until I need to do this again?
Old 01-22-2013, 02:28 PM   #46
Firstboost
My Ride: 2006 Tiag ZCP
I have only done it once when we swapped over to the CSL SMG software. Before that I had 68,000 miles with nothing more than a soft reset done.
Hope that helped a little. At any rate, as long as something physical isn't messed up, you should be good for a long time after you reset... If you go through all of that though, you may as well do the CSL flash.
Firstboost is offline   Reply With Quote
Old 01-24-2013, 01:53 AM   #47
Ballerbrian4u
Thanks man ! So you think I won't have to do it for a long time?
Old 01-24-2013, 03:25 AM   #48
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
You shouldn't have to do it for a while under normal driving. But it doesn't hurt to have it done every couple of years if you drive your car aggressively.
You will need a battery changer when performing the process.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 02-03-2013, 03:22 AM   #49
Ballerbrian4u
Hello guys, today I went to a fellow member and he preformed 4 thing on my car with his autologic. Fully adapt the gear box, teach clutch value valves, teach in clutch slip point,reset the clutch characteristic curve an I think I'm not sure he did a teach in of the longitudinal acceleration sensor. My problem is now the car when changing gears jumps 500 rpms when up shifting with out letting off the gas. What could this be? Also was it wrong to do these thing all at once? There is also another problem. When engaging 3 or 4 gear the clutch slips or dose not engage well. Pleaseeeee help me out I'm worried that I have messed up my car. He told me that all these thing will get better once the car has adapted. I hope it's true.
Old 02-03-2013, 04:56 AM   #50
turbo_f22_pilot
Give it a couple of days. Vary how you drive and your speeds. Drive it like you stole it and also like granny on sunday.
Joy is future proof
CAR:
MODS:
BMWCCA NCC
Old 02-03-2013, 09:56 PM   #51
devincox
My Ride: 2006 BMW M3 ZCP
I had a very similar result when I did this process with my AE for the first time. I found a thread over on m3forum.net where the op had the same issue. I did what he posted as the solution and my car has been shifting perfectly ever since.
http://m3forum.net/m3forum/showthrea...=343511&page=2
gl
devincox is offline   Reply With Quote
Old 02-03-2013, 11:11 PM   #52
Ballerbrian4u
gl
So if I read it correctly I should preform the clutch slip reset again?
Old 02-04-2013, 07:42 AM   #53
devincox
That's correct
Old 02-06-2013, 11:38 PM   #54
Ballerbrian4u
gl
Dose this problem only occur with the Autoenginuity smg reset? Because we used a autologic.
Old 02-07-2013, 12:00 PM   #55
devincox
I'm not sure. Of the posts, I have read, only the AE was mentioned. However, I have seen a few posts where it went exactly as planned when using the AE, so I suspect something else is to blame for the strange shifting after the update.
Old 02-07-2013, 01:24 PM   #56
Ballerbrian4u
Also at the time the suddering and jerkiness started a vibration type of noise started coming from the transmission or around that area at 1900 rpm. What could this be?
Old 02-07-2013, 04:04 PM   #57
Ballerbrian4u
It's only at 1900 rpm when cruising, accelerating and especially decelerating.
Old 02-07-2013, 06:22 PM   #58
devincox
Not sure bout that , my trans was doing some weird stuff until I reset it though
Old 02-08-2013, 05:12 PM   #59
Ballerbrian4u
Does anyone know what this noise is at 1900 rpm?
