Old 02-05-2013, 01:07 AM   #1
flameboy1696
My Ride: BMW 2006 330CI
Long Tube CAI on a Facelift Coupe
Good day all,
I was wondering if it's possible to install a Long tube CAI on a facelift coupe. I removed my driver's headlight today and i'm not sure how i could possibly do a Ballast relocation on these headlights.
Any of you have installed a Long Tube CAI on a facelift coupe in the past?
Here a picture of my headlight from the front the picture is old i'll try to get a picture from the top view of the one i've removed soon.
Thanks in advance
flameboy1696 is offline   Reply With Quote
Old 02-05-2013, 01:14 AM   #2
KrasivataSabine
My Ride: 323Ci
Injen, Dinan, and Cosmo V2 intakes come with hardware to replace the ballast.
Alternatively, I believe you can use the CSL ballast relocation part. I believe it's a genuine OEM part, you can look it up at bmwfans.info or something under the CSLM3
#BattleBimmer #323RS
KrasivataSabine is offline   Reply With Quote
Old 02-05-2013, 01:14 AM   #3
TrippinBimmer
My Ride: Just Fast!
There no way....
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 02-05-2013, 01:44 AM   #4
secono330ci
My Ride: 04' 330ci/15' A3 TDI
On a facelift coupe it's not as simple as just relocating the ballast. You need to open up the headlight, cut all 15+ wires, extend them about 2 feet or so, dremel the headlight housing for more clearance, etc.. I've done it, but it's a lot of work.
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 02-05-2013, 01:45 AM   #5
KrasivataSabine
My Ride: 323Ci
Oops. I learn something new everyday
Old 02-05-2013, 12:02 PM   #6
flameboy1696
Thanks for your answers guys ,
Secono , would you mind posting some picture of your setup please?
Thanks again!
Old 02-06-2013, 01:39 AM   #7
Steven747
My Ride: 05 330ci
im lost on my prefacelift coupe mine fit no problem with a little bit of a tight clearance but no biggy and no modification required
Old 02-06-2013, 01:42 AM   #8
TrippinBimmer
My Ride: Just Fast!
Your lost? Facelift don't have removable ballast....
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 02-06-2013, 02:15 PM   #9
Steven747
My Ride: 05 330ci
so how was i able to fit mine with zero issues?
Old 02-06-2013, 07:37 PM   #10
TrippinBimmer
My Ride: Just Fast!
you said it was a prefacelift. That Is why....
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 02-06-2013, 10:25 PM   #11
Steven747
My Ride: 05 330ci
Excuse me I meant facelift but I had Issues
Old 02-06-2013, 11:01 PM   #12
TrippinBimmer
My Ride: Just Fast!
Now you just confusing yourself...
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 02-06-2013, 11:55 PM   #13
Steven747
My Ride: 05 330ci
no issues*
Old 02-07-2013, 02:21 PM   #14
flameboy1696
Lol can you post picture of your setup Steven. Did cut the light or extended any wire.
Also which long tube do you use?
Thanks in advance!
Old 02-07-2013, 06:09 PM   #15
secono330ci
Steve probably doesn't have xenons
Old 02-07-2013, 10:30 PM   #16
TrippinBimmer
My Ride: Just Fast!
only reason I can think of...
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 02-07-2013, 11:01 PM   #17
Steven747
My Ride: 05 330ci
Thanks in advance!
Oem xenon Dinan long tube
Old 02-07-2013, 11:02 PM   #18
secono330ci
Can you take a picture?
Old 02-08-2013, 02:05 AM   #19
flameboy1696
^ i want a picture also!
Old 02-08-2013, 11:43 AM   #20
Steven747
My Ride: 05 330ci
Yes I'll post it up in an hour or so if the Mobil app lets me
