Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Suspension and Braking
Springs, shocks, struts, coilovers, camber plates, sway bars, strut bars, suspension bushings, control arms, brake pads, big brake kits, etc.
Old 12-25-2012, 06:58 PM   #1
325cicbmw
My Ride: 2005 DINAN S2 M3
Front KSport coil overs
I have a set of front only Ksport coil overs for sale. They were used for 2 months and have around 3000 miles on them. $400 shipped
From Kport,
Ksport Rally AR Spec Damper System is designed specifically for asphalt rally competition. It features extended stroke, heavy-duty internals, and simultaneous compression and rebound adjustment.
Most applications utilize an adjustable lower mount, meaning you adjust height without losing suspension travel like some coilover designs do. With the mounts and most pieces of the coilover being constructed of 6061 billet aluminum, the kit is lightweight, durable, and rust resistant. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
Ksport Rally AR Spec Damper System is designed specifically for asphalt rally competition. It features extended stroke, heavy-duty internals, and simultaneous compression .
Features:
Made from High Grade 6061 Aluminum with T6 for hardness
Electroplated Body - Protection from rust, corrosion and the elements
Monotube High Pressure Design
Mono vs Twin Tube Design
Dissipates Heat More Effectively
Allows for Finer Damper Adjustments
Cavitation & Aeration are Less Common
36 Levels of Damping Adjustment
Adjustable Compression / Rebound - Simultaneously
Adjustable Body - Allowing Maximum Suspension travel
Adjustable Spring Perch for Height Adjustment
Pillow Ball Top Mount with adjustable camber (availability varies with model)
Inverted steel shock absorber for durability
Lower center of gravity and higher chassis rigidity
Designed to reduce friction for cooler shock oil temperature
Inverted design like vehicles in WRC and all JGTC cars
1-Year Warranty
Spring Rates: 549
325cicbmw is offline   Reply With Quote
Old 12-27-2012, 09:51 AM   #2
325cicbmw
Price drop $350 shipped, I'll have pics up today
Old 12-27-2012, 01:38 PM   #3
Fern2899
My Ride: 2003 e46 M3
Send a message via AIM to Fern2899
Assuming this if for a non-m
Fern2899 is offline   Reply With Quote
Old 12-29-2012, 03:16 PM   #4
325cicbmw
Yes
Old 01-06-2013, 09:11 PM   #5
325cicbmw
sold
