Old 11-14-2011, 09:13 PM   #1
xXSHR00MIESXx
My Ride: BMW 330ci Sport Pckg
Send a message via Skype™ to xXSHR00MIESXx
Exclamation Facelift OEM Xenon Issue, dimming etc
Hey guys, Let me get straight to the point. I was driving back home when I realized my passenger side xenon was dimming. It then proceed to have this sequence when I turned off the lights and turned them on again.
After Turning on the lights Birght Normal Xenon Color, dim, shut off. RESTART Bright Normal Xenon Color, Dim, shut off. I did get the Front lamp was out but only for a second and only once. Which I find weird. I pulled over and turned off the car. Turned it back on this time it just dims. It does not flicker. I did research but couldn't not find an answer to my problem.
Any idea of what it might be? Igniter maybe? Bulb perhaps? Loose Connection? I will replug all connections tomorrow to see if its a loose connection..
Any help is greatly appreciated and will be rewarded with a e-cookie. Thanks!
My 2004 330ci , Picture Taken By E46_Moonlight
xXSHR00MIESXx is offline   Reply With Quote
Old 11-14-2011, 10:11 PM   #2
xXSHR00MIESXx
Anybody !?.. No ideas ??? nada?
Old 11-14-2011, 11:44 PM   #3
MeRon
My Ride: 325Ci
I don't think a loose connection, bad igniter or ballast would cause this issue. I'm willing to bet it's the bulb. Swap the passenger side bulb with the driver side and see if this still happens on the passenger side, if it stops on the passenger side and now started up on the driver's side then it's the bulb for sure. Else it would means something else other than the bulb. Hope that helps.
If you need new bulbs buy a PAIR of the philips 85122+ on ebay from a reputable seller, they are the best bulbs that stay white for its whole life without any color shift and they put out a bit more lumens than the regular 85122.
MeRon is offline   Reply With Quote
Old 11-14-2011, 11:46 PM   #4
ElrichMeister
My Ride: 06 325Ci M56
Swap Bulbs? See if it does the same thing, Also Swap Ballasts, just to rule out those parts?
ElrichMeister is offline   Reply With Quote
Old 11-15-2011, 12:26 AM   #5
MeRon
My Ride: 325Ci
OEM ballasts aren't easy to take out and swap, they are mounted under the headlights and require to pull off the headlights.
Old 11-15-2011, 07:01 AM   #6
xXSHR00MIESXx
I will do both and see, Thank you for replies. And Thanks for the Phillips Bulb Suggestion MeRon!
Old 11-15-2011, 10:42 AM   #7
xXSHR00MIESXx
OKAY UPDATE:
I have Swapped Bulbs, Problem persisted on the same head light. It's not The Bulbs. They both work Fine!
I have Swapped Ballasts, Problem Persisted on the same head light.
I have Swapped Ignite-rs, Problem Persists in the same head light!
Light Bulb Turns Pinkish/Purpelish then DIMS. The only thing I haven't swapped yet was that Little box above ballast. Could that be a problem?
I have a Video Coming up. I will Upload just now.
Old 11-15-2011, 10:54 AM   #8
xXSHR00MIESXx
Old 11-15-2011, 10:55 AM   #9
xXSHR00MIESXx
You can't Really see anything. But in the end Its quite obvious.
Old 11-15-2011, 01:04 PM   #10
MeRon
My Ride: 325Ci
Are you using Oem ballast and igniters?
Old 11-15-2011, 01:45 PM   #11
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
Purple light is a bad bulb.
Lol, was that highland park?
Old 11-15-2011, 09:48 PM   #12
xXSHR00MIESXx
I believe so. Gray square ballast and red black square igniter?
I have switched the bulbs. The "supposedly" bad bulb that originally was changing colors and diming was put on to my good head lamp and now works fine. It seems to be something on the passenger side. The only thing left for me to swap out and see if its the problem is that little box above ballast.
No that was Forest Park Bandshell parking area lol
Old 11-15-2011, 09:48 PM   #13
xXSHR00MIESXx
Oh I forgot to add my bulbs are H7 not the D2s type or w.e they are.
Old 11-15-2011, 10:39 PM   #14
MeRon
My Ride: 325Ci
If you have H7 bulbs then you don't have OEM HIDs as OEMs use D2S. Also all OEM ballasts are located underneath the headlight like I said earlier in this thread, they require the headlights to be pulled out to remove.
This sounds like the common issues that E46s have with aftermarket HIDs. Usually you get bulb-out warnings but some ballasts won't cause this, rather they flicker like in your case. You can try "bulb-out cancellers" to prevent the flicker; they are basically just capacitors. I would try that first and see if that resolves the issue.
Something like this:
http://www.ebay.ca/itm/HID-Xenon-Con...item4ab0a550cf
Old 11-16-2011, 03:42 AM   #15
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
If you have H7 that means your car never came with xenon lights. Do you have your car coded for xenon or do you have a wiring harness?
Old 11-16-2011, 06:05 AM   #16
xXSHR00MIESXx
I didn't touch the bulbs or the headlights since I got the car. It came like that so I assumed its OEM Xenon. It worked fine for couple of months since I had this car and it just started to DIM. It does not flicker. Just Dims. I will try to take and post picture of what it looks like. But this is a ballast I have which mounts on the bottom of the lamp
http://forums.bimmerforums.com/forum....php?t=1284979
and Ignitor
http://thumbs3.ebaystatic.com/m/mlbf...FkFfJw/140.jpg
So I am not sure if it has been coded for xenon or not or does it have thee wiring harness. I will try to take some pictures and post it up so you can see for yourself.
Old 11-16-2011, 10:38 AM   #17
xXSHR00MIESXx
OKay, I am completely lost. I've swapped the box above the ballast. And It is still doing the same thing. Is it possible something could've came apart inside the headlight... due to a bump or something? Also When you look at the silver rings on the headlight it says BMW DYNAMIC XENON... and everything else seems OEM. ???
Old 11-16-2011, 07:30 PM   #18
xXSHR00MIESXx
Well, Now I am baffled. Today I've got bulb error on the dash, and my passenger side wasn't lighting up at all. I have bought new bulbs, to replace and see if it does anything.
Old 11-16-2011, 08:01 PM   #19
TX78666
My Ride: 330i ZHP, N55 135i
No ideas, but subscribed for the solution.
Sorry.
Because... Grocery Getter.
TX78666 is offline   Reply With Quote
Old 11-16-2011, 08:06 PM   #20
nike001
My Ride: 2004 330i ZHP
Like said before, Try getting the bulb out error eliminator. I got mine from DDMTuning when I had my e39
330i ZHP 6MT | H&R Sport Cup | BMW Performance Intake & SSK | OEM Clears | WeissLicht Angel Eyes | Coby Wheel
nike001 is offline   Reply With Quote
