Old 12-25-2012, 08:50 PM   #1
bronxbomerss2
My Ride: 05 325CI
Send a message via AIM to bronxbomerss2
Starter problem?!
So just yesterday I drove the car all day and I left the car charger plugged into the cigarette lighter but I don't think that would drain the battery that much ? Any who I left the car outside last night it was in the mid 20s I believe I went to start the car it wouldn't turn over the battery seemed fine all the lights came on as normal. Im fearing the starter is the problem but is there anyway to make certain? I would appreciate any and all help considering from what I am reading this is a pretty big project!
bronxbomerss2 is offline   Reply With Quote
Old 12-26-2012, 12:41 PM   #2
Sil80m3
My Ride: 2003 325i
Tap the starter with a screwdriver/hammer. If the car starts after you do this, you need to replace the starter as the solenoid is going out.
Also, check the ground from the battery to the chassis. Make sure it is tight and corrosion free.
Sil80m3 is offline   Reply With Quote
