Go Back   E46Fanatics > E46 BMW > Sponsor Press Releases & New Product Announcements > Site Sponsor Specials and Sales
Find out about the latest specials and sales from our site sponsors here!
Old 12-26-2012, 09:08 AM   #1
obd2toolbox
Past Site Sponsor
My Ride: BMW 7
Bmw gt1 dis v57 sss v39 faqs!!
BMW GT1 DIS V57 SSS V39 Fit all laptops
Description:
DIS version: V57
SSS version: V39
Languages:
DIS: English,Chinese and Korea
SSS:English,Chinese,Japanese,Korea, Thai,Spanish,Italian,Dutch,Greece,Swedish,Indonesian,Turkish ,Portuguese,French and Russian.
Features:
BMW group tester one (GT1) is offered to the aftermarket in the same specification that is currently supplied to BMW franchised dealers. It is special-purpose tool of BMW Series.
Gt1 is supplied with a Pentium based laptop PC on a Windows platform connected to a high specification communications and measurement interface.
GT1 can complete coverage of ALL BMW systems, one thing that can only be done using the GT1, this function is called Electronic Control Unit (ECU) programming and configuration. Many of the original electronic systems on modern vehicles can now be re programmed using software; historically any changes to rectify software problems would involve a new ECU which would be purchased from the parts department and that is the only way that the independent market today is able to overcome these problems. The BMW GT1 system allows you re programme all BMW car ECU's to fix software or to install a blank ECU to a repaired vehicle. GT1 is the only system that allows you to do this and is absolutely essential if working on Freelander , the GT1 is also the only system that provides all diagnostics and programming for the very latest BMW launched this year.
BMW GT1 software kit comprises of five system ,TIS system .DIS data system ; diagnosis system .measuring system and management system . you can to test and check data information same time in GT1.
Test function :
Read faulty code ,clear faulty code ,data stream .activate state,programming ,component test ,maintenance data information ,components location ,wiring diagram etc...,TIS AND DIS ARE SUPPLY all of system diagram of all of BMW car, Components location, maintainence method and coding information etc. Can do completely of BMW car system.
Package including:
1. GT1-SCAN Pro mainbody
2. Network cable
3. GT1 for vehicles with 20pin diagnostic connector
4. GT1 for vehicles with OBII diagnostic connector
FAQ:
Q: What is the difference between GT1 and OPS?
A: They have one same function is diagnose. GT1 is good for cars before 2005 while OPS is good for cars after that, and OPS can do 2009 year models. OPS can do coding and programming for cars with fiber.
Q: What is this version BMW GT1 different from GT1 DIS V57 SSS V32 Fit IBM T30?
A: There are two differences. First one, this version GT1 do not limited on IBM T30,it can work with any laptops, as long as this laptop support USB 2.0. Second, this version GT1 DIS version is V55 while IBM T30 version is V57.
Q: Which car this device mainly does?
A: It can do almost all of the BMW from 1988 to 2005, BMW OBD1, BMW OBD2 and cars without fiber.
Q: What's the function of the two systems: SSS and DIS?
A: The DIS is used to diagnose, and the SSS is used to program.
Q: why there is a network cable in this package?
A: As you must connect with your computer during use this item, what's more, your computer must connect with the Internet. During the diagnosis, only the device finds your computer ID, orange signal light flashes and connects successfully, you can do diagnosis.
Q: What should I pay attention to during use this item?
A: 1. Please do not disconnect the power and network cable when you test your car, if there is any problem, please press reset light.
2. You'd better keep your maximal car power under 15.2V, if the power above 16V, it will be out of power automatically.
3. When you install the mobile HDD (fit all computer HDD), you need to close the anti-virus system, otherwise you will damage the inside file.
4. When you use mobile HDD (fit all computer HDD) and want to close this software, please close the "power off" of VW PLAYER, rather than close it directly.
Q: If it can do ECU programming for BMW 1996 328i?
A: Yes, it can do.
obd2toolbox is offline   Reply With Quote
