Old 02-20-2013, 08:25 AM   #1
ventresca
My Ride: 1998 E46 320i
Jerking Clutch v2.0 :)
Hi everybody,
Let me introduce my adventure with my clutch, some time ago I was helped by dmax to solve a jerking clutch issue, the message that speaks about it is this:
http://forum.e46fanatics.com/showthread.php?t=927156
I was really happy at that time because the issue seemed solved, but after a week the clutch started again to buck so I've bedded the clutch for another 2 times but with the same result, after a week or 3/4 days the clutch started again to buck!
I remembered that dmax said that the last resort was to bleed the clutch, so I've changed all the brake fluid (2 years old so time for a full replacement ) and when we bleeded the clutch slave cylinder (after the brakes bleed) we noticed that lot of bubbles squirted out.
After the clutch bleed the clutch was like new!!!! No jerks, no buks, smooth starts also at 800 rpm, also in the heavy traffic with no problems at all.
Also this time after a week I started to experience the old buck issue.
The clutch starts to jerk near the complete release of the pedal, it is more evident when the engine is cold less when it works in the correct temperature.
Now I'm experiencing also an ugly noise when I start the engine after the night rest, the noise disappear when I press the clutch pedal and when the engine is hot.
I think that the issue is in the master/slave clutch cylinder, maybe one of them let in a small amount of air and do the issue.
I'll try to bleed again the clutch to see if I still have bubbles that squirt out of the cylinder, if it occur maybe a cylinder replacement could be the answer.
So please anyone have (dmax for example ) an Idea/clue/suggestion about this issue?
Thanks a lot to everybody!
Ciao.
Fabio.
ventresca is offline   Reply With Quote
Old 02-20-2013, 08:33 AM   #2
Patton323I
My Ride: R1100GS E46 E53
If you had a bad seal in the slave, it may cause fluid to bleed past and cause the cylinder to disengage prematurely.
Patton323I is offline   Reply With Quote
Old 02-20-2013, 08:48 AM   #3
DHK
My Ride: 2002 BMW 325Ci
Don't know how serious your issue is, but in every manual Ive ever driven if you are timid with the gas pedal when releasing the clutch you get bucking, especially when everything is cold.
Is this normal? I don't know but in my experience being liberal with the gas is the best solution until everything gets warm and toasty.
DHK is offline   Reply With Quote
Old 02-20-2013, 09:19 AM   #4
ventresca
The issue is more evident when the engine is cold, but it do not disappear at all when the engine is hot, also if i raise the rpm up to 1500 when I release the clutch.
You're right, btw I'm a bit experienced with the manual shift and I assure you that the problem occurs also when the engine is hot (with a clutch release with both low or high rpm ).
Thank you for your help.
Ciao.
Fabio.
Old 02-20-2013, 09:23 AM   #5
ventresca
And so a premature disengage could jerk the start!
This sounds good!
Thank you!
Ciao.
Fabio.
Old 02-20-2013, 09:26 AM   #6
lcoleman
My Ride: '79 Massey Ferguson
This sounds like a throw out bearing, which may or may not be related to your issue.
A lot of bubbles in the line sounds like a leak somewhere, though. Gotta dig around the master and slave and look for fluid leaks.
Old 02-20-2013, 05:02 PM   #7
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Sounds like you got some good advice. I'd certainly look to see if you see fluid from the clutch slave or the master. Mine are amazingly still good, but they, like all parts, can fail. Beyond that, you got me...I've seen many clutches and understand the principle, but I wouldn't want to offer advice on whether it's something internal. Throwout bearing, I believe will rattle when your clutch is down when it's bad, but it might have other symptoms too, like sticking...IDK.
GL!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 02-20-2013, 05:52 PM   #8
Andy2108
My Ride: SpecE46 & E46 M3
Looks for fluid leaks.
Does your car have a clutch delay valve? Search for that or CDV to see what I'm talking about.
De gustibus non est disputandum.
Old 02-21-2013, 03:04 AM   #9
ventresca
Hi dmax I'm happy to hear you again!
Last time that we bleeded the clutch we didn't see any fluid around the slave cylinder, we have to check again the slave and the master.
I've asked about you because last time you gave me a lot of good clues and suggestions, and for me you are a bit Italian!
GL!
OK, I understand.
First of all I have to bleed again the clutch and check both the clutch cylinders, if the problem is there I'll change one or both the cylinders.
If the cylinders are good and no evident leak from the circuit, I have to pull down the gearbox and check all the clutch system (maybe at 155.000 Km if I have to pull down the gearbox I should think to replace the clutch anyway).
I think that in the end I should pull down the gearbox anyway to check the throw out bearing and the clutch system...
Thank you again!
Ciao.
Fabio.
Old 02-21-2013, 03:08 AM   #10
ventresca
My car is a 1998 320i, no cdv, the cdv is for "real" engines not for little farts!
Jokes apart, for small cubes e46 bmw do not puts the CDV, the torque is too low to damage the clutch/gearbox.
Thank you for the help.
Ciao.
Fabio.
