Engine & Performance
Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 12-26-2012, 03:31 PM   #1
silver46
My Ride: United States
FS: used VF Engineering Stage 2 Supercharger Kit. E46 M3
VF570 KIT
Supercharger was upgraded via Vortec. suports 775hp. only few miles since upgrade.
Included 3 pulley size. The current installed pulley is 2.62 which produced 12psi at utah elevation. was using methanal injection and upgraded fuel system sold separately.
Includes Greddy Blow off valve set to vent to atmosphere
Kit puts down over 500whp on a dynapack with methonal and higher boost.
You will need to purchase 1 check valve of which is a few dollars
mounting brackets required for water reservoir
2 fittings for the water lines and finally you will need to send out your ECU to VF for programming
VF570 Supercharger System
Supercharger system setup for 8.5-9.0 PSI, V3-SQ trim supercharger with air/water cooled cartridge inside cast intake manifold. OEM spring tensioner upgrade, Stage 2/3 Bosch fuel injectors, Hitachi MAF conversion, with custom Software flash. Requires sport Cats downstream from header. Cold weather requires boost gauge monitoring and AFR gauge monitoring.
stage 2 rated specs via 2.7 pulley and without methanol.
PSI: 8.5-9.0 (Stock: n/a)
Horsepower: 570, 600 w/ race gas (Stock: 333)
Torque: 380, 400 w/ race gas (Stock: 262)
Components When Upgrading From VF480 System to VF570 System
- Custom tuned software flash
- Replacement 8.5-9.0 psi supercharger pulley
- Replacement OEM serpentine belt
- Replacement fuel pressure regulator
- Replacement serpentine belt tensioner
- Stage2/3 OEM High flow spray pattern matched fuel injectors
- MAF upgrade conversion
- Larger K&N induction filter
asking $7k
images:
http://www.ksl.com/index.php?nid=389...sid=23408713#1
email richard_gibby@comcast.net
silver46 is offline   Reply With Quote
Old 12-30-2012, 01:26 AM   #2
silver46
http://www.ksl.com/index.php?nid=389...sid=23408713#2
Old 12-30-2012, 01:30 AM   #3
silver46
Added images
ID:	483955   Click image for larger version
Old 12-30-2012, 03:39 AM   #4
Edgar3498
My Ride: 330CI
What pulleys do you have
Sent from my SGH-T999 using Bimmer App
Edgar3498 is offline   Reply With Quote
Old 12-30-2012, 04:36 AM   #5
silver46
3 pulleys. The one for low boost for the 420kit. The 2.7 inch for the upgraded 570 kit and 2.62inch which does 11-12psi at Utah elevation.
Old 12-30-2012, 05:41 AM   #6
Edgar3498
My Ride: 330CI
Would you sell the 2.7 or the 2.61 pulleys by them self. How much boist is the 2.7 8-9 psi
Old 12-30-2012, 01:26 PM   #7
silver46
The 2.7 was hitting 10 psi. The supercharger was upgraded recently. I really don't want to part the kit tho who ever buys it might sell the other pulleys they don't use.
Old 12-30-2012, 04:06 PM   #8
Edgar3498
My Ride: 330CI
Would you sell the 2.7. With one do you have on there
Old 12-31-2012, 02:56 AM   #9
M369
My Ride: M3E30 V10!!!
With 2.61 pulley how Many hp Max?
M369 is offline   Reply With Quote
Old 12-31-2012, 05:59 PM   #10
Edgar3498
My Ride: 330CI
Did you have slippage
Old 01-01-2013, 03:28 AM   #11
M369
In new the kit cost 7645$
http://m3forum.net/m3forum/showthread.php?t=426958
Old 01-01-2013, 04:01 AM   #12
silver46
That 7k price was for black Friday only. With the 2.6 it was hitting 500whp+. I was running meth injection and an upgraded fuel pump. Both are for sale too.
Old 01-01-2013, 04:02 AM   #13
silver46
No slippage. Was running a smaller tighter belt.
Old 01-01-2013, 04:42 AM   #14
M369
Do you have vidéo And dyno of your car?
Old 01-01-2013, 10:46 AM   #15
Edgar3498
My Ride: 330CI
Are u willing to sell the 2.7 pulley im very interested in it
Old 01-01-2013, 11:11 AM   #16
Edgar3498
My Ride: 330CI
Old 01-03-2013, 07:40 PM   #17
silver46
Bump! Dont want to separate the pulleys.
Old 01-03-2013, 10:30 PM   #18
Edgar3498
My Ride: 330CI
Ok thanks anyways
Old 01-14-2013, 05:26 PM   #19
silver46
Bump!
Old 01-15-2013, 05:11 PM   #20
silver46
Bump!
