Re-glue facelift headlight? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 12-26-2012, 03:36 PM   #1
WheyArea
My Ride: '03 TiAg ///M3
I've been debating whether or not to bake my headlights in order to get some nice AE's in there. My only concern is that I've heard mixed things about re-sealing the headlight and don't want to have them fog up or catch moisture. For anyone who has done it successfully what sealant did you use?
/// Dinan ECU /// Brembo BBK /// BBS LM 19" /// Bilstein PSS10
/// Eisenmann Exhaust /// Supersprint Mid Pip /// AC Schnitzer Spoiler
/// Hamann Lip /// AC Schnitzer CF Diffuser /// K&N CAI /// Valentine 1
Coming Soon...... OEM SSK, CSL bootlid
WheyArea is offline   Reply With Quote
Old 12-26-2012, 03:40 PM   #2
pawelgawel
My Ride: 330CI
I've never done it, but it seems to me you don't need to add anything if you don't scrape anything off... use a heat gun in stead of baking.
heat it up again when install and press hard enough to gain a complete contact on all sides... shouldn't have any problems if done properly.
Sent from my SGH-I727R using Bimmer App
pawelgawel is offline   Reply With Quote
Old 12-26-2012, 06:08 PM   #3
WheyArea
So just re-use the adhesive already there? That's where my concern is because it's 7 years old and I imagine anytime you rip apart adhesive it's best to clean it up and re-seal (aquariums, furniture, windows etc)
Old 12-26-2012, 06:18 PM   #4
pawelgawel
My Ride: 330CI
you're heating it up to a point that the glue particles split.. so technically if you heat it up to the same temperature once ready to glue back together, it will bind the way it was originally. just make sure you do it thoroughly.
if you are seriously worried, use silicone, but that will get messy if you need to go back in.
Old 12-26-2012, 07:32 PM   #5
pawelgawel
My Ride: 330CI
solidjake did his facelift.. give him a shout
Old 12-27-2012, 03:38 AM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Facelift sedan yes, not a coupe...
Old 12-27-2012, 04:00 AM   #7
WheyArea
How did you re-seal your headlight and did it hold up?
Old 12-27-2012, 07:39 AM   #8
|2eckLesS
My Ride: 2004 330ci
facelift coupes are the only ones that you have to bake. I have not done it, and I am hesitant to even try because of the moisture. I think you are right, something that is ~8 years old I would think you should clean re-glue/epoxy/seal the head light. even if you reheat it to the same temp as previously stated, you will not have the same bond because you have broken that bond down through heat and separation (particles that once held together will not all hold the same as they did on the first seal)
Other option - drop the money and get the depo's with AE's. ~500 to 700 and from what I have read, the quality is no where near the quality of OEM. Loose loose.
My 330 will continue with the OEM, as there is a lot better things I could spend 500 on before lights.
|2eckLesS is offline   Reply With Quote
Old 12-27-2012, 09:11 AM   #9
Jesse M
My Ride: 05' ZHP
When I installed my AE's into my facelift headlights I had to bake them. They came apart very easily. I disconnected the headlight and ballast obviously. As far as putting it back together, I just put the two halves in the oven for a few mins, then squeezed them together with a towel and some tape for a few more mins until the glue hardened. I went through an entire year like that, never had a single problem and never fogged up.
Jesse M is offline   Reply With Quote
Old 12-27-2012, 10:18 AM   #10
jmillsner
My Ride: 330Ci 6 Spd, 335Cic
did you put them on a year ago or did something go wrong? im also interested in putting AE's into my '04 Coupe im just too worried about something going wrong in the future
jmillsner is offline   Reply With Quote
Old 12-27-2012, 10:37 AM   #11
Solidjake
Zero. Leaks.
Solidjake's Avatar
Sedans have clips
Old 12-27-2012, 10:39 AM   #12
quiksilver4drM3
My Ride: 330ci
I've done it on a set of e39 headlights which are the same process. I just ran a line of silicone within the grove of the old sealant, reheated with the heat gun and applied the lenses. Since I've did them there has been no fogging, moisture, no issues.
quiksilver4drM3 is offline   Reply With Quote
Old 12-27-2012, 02:44 PM   #13
WheyArea
Ok I'm convinced. I'm gonna order some AE's and do it next week. Any suggestion on lights?
Old 12-27-2012, 02:46 PM   #14
Solidjake
Zero. Leaks.
Solidjake's Avatar
http://www.umnitza.com/predator-orio...pe-p-1247.html
Old 12-27-2012, 02:47 PM   #15
Russian172
My Ride: e46 sedan e46 m3
When I did this on my facelift sedan I didn't bake or resell anything so far so well like 3~4 months
Russian172 is offline   Reply With Quote
Old 12-27-2012, 03:02 PM   #16
|2eckLesS
My Ride: 2004 330ci
Because facelift sedans have clips no need to bake. Ill be watching and waiting and might tackle this as well. I just hate to put my nice headlights in an oven....
Old 12-27-2012, 03:04 PM   #17
Jesse M
My Ride: 05' ZHP
Put them on a year ago and took the headlights out and sold them working perfectly fine. I upgraded to the Umnitza P46 FX-R, LED, AE, HID setup..
Old 12-27-2012, 03:05 PM   #18
Jesse M
My Ride: 05' ZHP
The heat will not do anything to your lights so as long as you follow the recommended procedure. 150* for 15 mins or so. All that will do is soften up the glue, it will not deform any plastic what so ever.
Old 12-27-2012, 07:05 PM   #19
|2eckLesS
My Ride: 2004 330ci
How do you compare the Umnitza HID's vs OEM?
Old 12-28-2012, 11:56 AM   #20
WheyArea
I'm interested too
