Old 12-26-2012, 05:38 PM   #1
metlic53
My Ride: 2003 BMW 330i
325i engine with 330i engine?
as some of you know i have a cracked head and i don't know how the previous owner drove it so its probably not a good idea to just get a new head cause i don't know the shape of the aluminum block.
Will the 3.0 out of a 330i bolt straight into my 2001 325i? what years are compatible with this swap? any advice?
metlic53 is offline   Reply With Quote
Old 12-26-2012, 05:54 PM   #2
bimer21
My Ride: stick 325i
I heard is same wires sensor swap by itself is same but you will need to change some modules and reprograming then!
bimer21 is offline   Reply With Quote
Old 12-26-2012, 06:03 PM   #3
Zchild
My Ride: 2000 BMW 3XXi ZSP
I'm pretty sure your 2001 E46 325i came with a M52TUB25 motor and the 330i came with a M54B30 motor. Therefore its not a straight swap... I had the opposite issue in which OI spun a bearing in the lower block of my M52TUB25 motor so I used my M52TB25 head unit and paired it with a M54B30 block. In other words I used my original 323i head unit and a 330i block, crankshaft and injectors to put my car back on the road. Main issues are the 330i motor is drive-by-wire and I believe the 325i motor has a cable throttle body. Secondly the MAF is larger as are the intake hoses and the DME software is different. Those are just a few of the issues you will have to overcome in order to do a straight swap.
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 12-26-2012, 06:06 PM   #4
Hornung418
My Ride: '04 MB ZHP
325i was equipped with an M54B25. Its a direct swap all that is needed is some coding of the MS43 DME.
Sent from my SCH-I535 using Bimmer App
Hornung418 is offline   Reply With Quote
Old 12-26-2012, 06:29 PM   #5
TerraPhantm
My Ride: M3 & ZHP
More or less a direct swap. Best to grab the intake from the 330. Plugging all that in and installing a 330 tune on your DME should do the trick
Old 12-26-2012, 06:59 PM   #6
stookin
My Ride: 2001 bmw 330i
yup direct swap.
stookin is offline   Reply With Quote
Old 12-26-2012, 07:05 PM   #7
Alex323Ci
My Ride: M3 & 323Ci (sold)
1999-2000 323/328 M52TU line of engines
2001+ 325/330 M54 line of engines (some M56)
2001 325 is a 2.5L M54
Old 12-27-2012, 11:16 AM   #8
metlic53
well i'm going to start looking for an engine then. Whats the latest year i could get and it be a direct swap? is there a certain year that was "better" than the other? i'm hoping to find one with 90k miles or lower, i found one already with 90k and they wanted 2 grand for it (not too bad)
Old 12-27-2012, 11:17 AM   #9
stookin
01-05
Old 12-27-2012, 11:22 AM   #10
My Ride: Lexus
If I were you, i'd go for 03+. they seem to be mostly free of oil consumption problems for some reason
Old 12-27-2012, 11:39 AM   #11
Zchild
Cool
Thanks Alex, appreciate the right information, you da man; the fact that it is still a 2.5L confused me I assumed incorrectly thatr the M54 only came as a 3.0L motor.
Old 12-27-2012, 02:14 PM   #12
Commando
My Ride: M3 - SMG
Would it be reasonable to assume the M54 out of a 5 series would be suitable also. I assume some of the periperal plastic will not fit. Is it possible to do "some coding" or a "330 tune" with INPA etc. maybe by changing the VO? Or does this mean replacing the DME?
Commando is offline   Reply With Quote
Old 12-27-2012, 02:16 PM   #13
My Ride: Lexus
3, 5, X3, X5, Z4, 04' E60 530, doesn't matter
Old 12-27-2012, 02:23 PM   #14
Hornung418
My Ride: '04 MB ZHP
Oil pans are different between chassis, but the block and head are the same.
Old 12-27-2012, 02:27 PM   #15
My Ride: Lexus
right, thats common knowledge. theres a bunch of other stuff that op will have to switch over as well depending on what year engine he gets. he'll handle it
Old 12-27-2012, 03:08 PM   #16
Hornung418
My Ride: '04 MB ZHP
I wouldnt say its common for everyone to know that. OP should be made aware of the differences regardless if he knows or not.
Best of luck with the swap OP.
Old 12-27-2012, 04:01 PM   #17
Alex323Ci
I agree, it's not common knowledge to everyone. Especially someone asking if its the same engine.
Good info
Old 12-27-2012, 04:07 PM   #18
My Ride: Lexus
Good info
I know. that's why i told the OP what cars he could source the engine from
it'll be painfully obvious when the pan is sticking out or doesn't fit.. give the OP more credit.
Old 12-27-2012, 05:14 PM   #19
metlic53
What mileage should I look for? I'm gonna try and get 90k or lower
Old 12-27-2012, 05:28 PM   #20
metlic53
i found one out of a 03 z4 with 66k miles for 2500 with 90 day warranty
