Old 01-17-2013, 02:20 AM   #61
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
yes
and I would hope he changed the software - wouldnt it run lean - even with the larger injectors, tb, etc
/_________\
O==[][]==O
Old 01-17-2013, 02:29 AM   #62
TerraPhantm
My Ride: M3 & ZHP
Originally Posted by 330i ZHP View Post
yes
It might be able to correct it based on the lambda values. If lambda = 1, then fuel and air are at stoichiometric ratios. Where he would run into issues is at WOT, since WOT isn't target based on the ms43
That said, if he has 330 injectors and 325 software, there is a chance it wouldn't run lean even at WOT -- depends on the flow rate of the injectors.
Old 01-17-2013, 02:34 AM   #63
330i ZHP
330i ZHP's Avatar
his car is 2001 - so def MS43
/_________\
O==[][]==O
Old 01-17-2013, 10:24 AM   #64
metlic53
My Ride: 2003 BMW 330i
I believe it has 325i injectors with 330i software
metlic53 is offline   Reply With Quote
Old 01-17-2013, 10:25 AM   #65
metlic53
Oh and using 325maf 325 TB
Old 01-17-2013, 10:28 AM   #66
TerraPhantm
My Ride: M3 & ZHP
You are almost certainly running lean. Get the 330 injectors and 330 MAF.
330 tune is programmed with larger injectors in mind. So it fires them at durations intended for that specific size. If you were to install smaller injectors, it'll still open the injectors for the same duration. Net result is less fuel. The restriction of your current intake setup is not enough to account for the reduced fuel.
Further more, the 325 and 330 MAF almost definitely don't have the same calibration. So the DME thinks its getting X kg/h, while in reality it's getting Y.
Basically your engine has no idea how much air and fuel it's getting. As you can imagine, those are very important parameters to running an engine. It can correct based on lambda values, but that'll be less than optimal. Also the lambda is ignored at WOT -- so your car can be downright dangerous to drive at full load.
Old 01-17-2013, 11:02 AM   #67
metlic53
ok i wont WOT it, so leave the normal intake on? i have a buddy that blew his 330 and got a whole engine for his and he has all the stuff i can grab the maf, injectors and intake.
Old 01-17-2013, 11:47 AM   #68
stookin
My Ride: 2001 bmw 330i
cel isnt gonna go away by itself spanky
stookin is offline   Reply With Quote
Old 01-17-2013, 11:49 AM   #69
metlic53
i'm looking online and the part number for the 325i maf sensor is the same part number for the 330i maf sensor?
so that would mean i wouldn't need to change it right? maybe just needs a cleaning?
Old 01-17-2013, 11:51 AM   #70
metlic53
it wont? the mechanic said i needed to drive 50 miles and if it didnt go away to get a new MAF sensor or clean it and see what happens. Do these cars require the 50 miles reset?
Old 01-17-2013, 12:07 PM   #71
stookin
why wouldnt he reset it??? the light needs to be reset, the code is already stored so its not goin anywhere. only thing driving it 50 miles is going to do is put the car through its drive cycles and set the monitors. thats after the light is reset. At which point while its doing that its going to check for any malfunctions.... and if your maf is ****ie it will probably throw the light again.
Old 01-17-2013, 12:09 PM   #72
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
U r looking at the wrong section. The 325 SULEV (m56 engine) uses the same MAF as the 330
sent from my HTC EVO+ using Bimmer App
Old 01-17-2013, 12:35 PM   #73
metlic53
ohhh i see it now, dang, thats 236 bucks...
Old 01-17-2013, 12:37 PM   #74
flashmeow
Banned User
Nope..u can get it cheaper at Bma autoparts for $175 with free shipping. Woot woot
Old 01-17-2013, 01:48 PM   #75
metlic53
really? Thats where i was looking but it was 236
http://www.bmaparts.com/ShopByVehicl...Sensor&mode=PA
Old 01-17-2013, 06:02 PM   #76
flashmeow
Banned User
check the year again cuz I just checked my receipt and saw that it was actually $162 (with the 10% discount).
The 330 MAF I got is the one without the integrated AIT sensor (3 pin) found on earlier 330s.
good luck
Old 02-01-2013, 01:41 PM   #77
metlic53
Well that engine threw a rod out the side of the block only 500 miles into driving it, their installing another one free......I was driving 50 in 5:30 traffic in Houston and it blew up....200 dollar tow truck...
Old 02-01-2013, 02:30 PM   #78
Alex323Ci
My Ride: M3 & 323Ci (sold)
Originally Posted by Alex323Ci View Post
sounds pretty good, just make sure you get some kind of warranty. engines with front end collisions sometimes mess with the engines balance and internals.
it's just good to have incase.
Good thing for that warranty
Old 02-06-2013, 03:40 PM   #79
metlic53
i know right, hopefully he will be done in a week...taking forever...my lifted as all get out jeep cherokee sucks gas like a pig...
Old 02-06-2013, 05:36 PM   #80
Levim9
My Ride: S54 325i & LSB M3
Cool thread OP! Be glad the engine failed that early and didn't fail right after the warranty ran out. I'm sure the next one will work out for you. Keep us updated and post pics when you get it back.
Levim9 is offline   Reply With Quote
