Old 12-26-2012, 09:51 PM   #1
cakahl
My Ride: 2001 325ic
Camshaft Cut in 2 Separate Pieces HELP!!!
Ok guys,
Sorry for the long thread but I feel like I should tell the whole story to get a good overview of what I'm dealing with.
So I bought my first E46 about a month ago now it's a 2001 325ci automatic transmission with 109k miles. I got a great price for it about half of blue book value, so I figured it was gonna take some tlc to get it back into shape. The day after I bought it I noticed a slight oil leakage. I ordered a valve cover gasket replacement to try and fix oil leak. In the process of this when I removed the valve cover I found that there was a whole lot of sludge within. I found some diy's that said to remove as much as possible then go with the seafoam solvent to get rid of it through oil changes. After replacing the head cover gasket I was on my way to work on the freeway and the low oil light came on. A few seconds later the car has a very rough time accelerating and drops down to about 45 mph. I get off on the next exit and then when I come to the stop light the car dies. It will not start back up. I tow it back to my place and open up the valve cover and see that 2 of the bearing caps holding down the Exhaust Camshaft (part #11311435416) had cracked in two and one of them was rubbing up against the cam for too long and completely split it in two! Now I have seen some diys on replacing this and it seems very difficult. I have found a used camshaft on ebay for around $200 but am debating doing this myself. I do not really have the thousands of dollars I'm sure it would take to have the dealership do it so what are my best options? Does anyone have a part number for the bearing caps? Here are some pics attached to give you guys a better idea of my current state.
ID:	483529   Click image for larger version
ID:	483530   Click image for larger version
cakahl is offline   Reply With Quote
Old 12-26-2012, 11:59 PM   #2
MotorMan
My Ride: e39
Unfortunately you need more than just the caps. You will need the entire cam journal assemblies, and they run more than $425 a piece. You also likely have an oil feed obstruction to the cam journals. I would suggest finding a good used head.
MotorMan is offline   Reply With Quote
Old 12-27-2012, 03:30 AM   #3
kd7iwp
My Ride: 2001 325i
I'll second the head.
kd7iwp is offline   Reply With Quote
Old 12-27-2012, 02:34 PM   #4
cakahl
My Ride: 2001 325ic
What is the part # for the head do you guys know?
Old 12-27-2012, 02:38 PM   #5
Russian172
My Ride: e46 sedan e46 m3
let it be ultimate valve control cut off ??
run on less cylinders
Profit ?
Russian172 is offline   Reply With Quote
