Australia
Old 12-27-2012, 02:43 AM   #1
rodsfromday
My Ride: 323CI
Vanos seals replacement
Posted in main forum as well.
It's been long overdue so, following the Beisan guide, started earlier. When I removed valve cover this is what I found.
It's a lot of old grease and crap. Is that normal? What's the best way to clean it all up.
Thanx.
Sent from my GT-I9300 using Bimmer App
German Engineering at its best
rodsfromday is offline   Reply With Quote
Old 12-27-2012, 03:02 AM   #2
Brissyjohn
My Ride: 2007 MX-5
Not normal.
IMO, you're going to have to button the whole thing back up again, drain the oil and run some clean oil and an engine flush through and drain again. You'd need to do this until you get all that sludge out.
Brissyjohn is offline   Reply With Quote
Old 12-27-2012, 03:14 AM   #3
rodsfromday
My Ride: 323CI
Originally Posted by Brissyjohn View Post
Not normal.
Yeah I have my work cut out for me tomorrow. Will need to get some engine flush and cheapo oil. Would I be able to use a degreaser on it? I would imagine it would flush out as well?
Old 12-27-2012, 03:50 AM   #4
HBizzo88
My Ride: 2002 bmw 330ci
Fill it with cheap oil and about half a can of sea foam. Drive 50 miles or so, then drain it while its still warm.
I swear by that stuff. Works great IMO.
HBizzo88 is offline   Reply With Quote
Old 12-27-2012, 05:05 AM   #5
Brissyjohn
My Ride: 2007 MX-5
I would not use degreaser.
Old 12-27-2012, 05:08 AM   #6
rodsfromday
My Ride: 323CI
Thanx
no worries, thanx
Old 12-27-2012, 05:13 AM   #7
HBizzo88
Originally Posted by rodsfromday View Post
Thanx
no worries, thanx
Welcome, let me know how it goes!
Old 12-28-2012, 03:24 AM   #8
rodsfromday
My Ride: 323CI
Will do!!
Old 12-28-2012, 03:29 AM   #9
Jall
My Ride: 328Ci
I don't know about seafoam, Auto RX is probably a more suitable product.
Don't know about the availability in Australia, I think Sprintman used to be/have a connection to the distributor.
You've got me scared to take mine apart to do the seals now.... :/
Jall is offline   Reply With Quote
Old 12-28-2012, 03:51 AM   #10
rodsfromday
My Ride: 323CI
I will try the diesel route first and then take it from their.
If it needs to be done then it must be done!! I might even tackle the OFH gasket....
Old 12-30-2012, 03:14 PM   #11
Ballistic325
My Ride: slow and steady
Concur with the above - engine flush + cheap oil until it starts looking clean again. I haven't used seafoam or Auto RX so I can't comment.
As for the VANOS, I'm tackling this early next year, time permitting. I would say that you should leave the OFHG for another time. Focus on getting this DIY right first without adding to potential complications.
If you were any closer I'd come in and give you a hand (more so to get a first hand sticky beak for myself! )
Good luck and keep us posted
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 12-30-2012, 03:34 PM   #12
rodsfromday
My Ride: 323CI
Yeah i am just waiting on my lower intake boot and oil filter from Lucas, then i will see how my vanos DIY went. It rather quite simple. I thought it was gonna be a killer.
Yip i am canning the OFHG change for now. That sludgy engine just broke my steam a bit.
I will do a flush with the current oil in, then change to the cheapie oil and then do another flush.
Thanx.
Old 12-31-2012, 05:19 AM   #13
Brissyjohn
My Ride: 2007 MX-5
Glad you got it done. Man, I've never seen that much sludge in an engine...ever.
Old 12-31-2012, 08:48 AM   #14
rodsfromday
My Ride: 323CI
Yes I will never allow that too happen again.
Old 12-31-2012, 10:51 PM   #15
trive2
My Ride: 1989 BMW 535i
What oil were you using and at what intervals?
trive2 is offline   Reply With Quote
Old 12-31-2012, 11:22 PM   #16
rodsfromday
My Ride: 323CI
I've owned the car for just over 2 yrs now. This is my second service as i service every 5000 km. I have been using this oil.
From what i discovered, maintenance by the previous owners was just shite!!
Old 01-01-2013, 04:58 AM   #17
Brissyjohn
My Ride: 2007 MX-5
Try this
or this
Both meet BMW LL-01
Old 01-01-2013, 05:12 AM   #18
trive2
Castrol Edge Titanium 0W-40 and Mobil 1 0W-40 are considered to be the best oils by general consensus.
Old 01-02-2013, 04:24 PM   #19
sprintman
My Ride: Ex 325CI owner
Decent oils but maybe not the best. At least they meet spec.
sprintman is offline   Reply With Quote
Old 01-02-2013, 07:55 PM   #20
Ballistic325
Try this
or this
Both meet BMW LL-01
Not a big fan of the Shell. Am doing a run of the Penrite to see results...
How are you doing, Rod?
I can help with
* RTABs
