Australia
Old 12-27-2012, 05:20 AM   #1
f4n4tik
My Ride: M-Sport 320Ci e46
Powder coating
What is a fair price for a gloss black powder coat on a set of 19" wheels, or even painted ??
f4n4tik is offline   Reply With Quote
Old 12-27-2012, 07:14 AM   #2
steve.k
My Ride: 05' 325Ci, 13' WRX
'Painted' - I presume you mean Wet Spray Vs. Powdercoating. Powdercoating around $100-200 per rim depending on where you go and what colour you want done, wet spray roughly the same. Powdercoating will give far better durability over wetspray although wetspray in some instances will provide a better finish.
steve.k is offline   Reply With Quote
Old 12-27-2012, 08:02 AM   #3
f4n4tik
Cheers for the info.
Old 12-27-2012, 06:00 PM   #4
YGOAMG
My Ride: 325Ci ClubSport
Send a message via MSN to YGOAMG
I got mine done for about $190 per wheel. + transport
Powder coated
Find me on Instagram
@PeterMarquez346
Originally Posted by all4show View Post
who da F done that?
prestige warehouse or who?
YGOAMG is offline   Reply With Quote
Old 12-27-2012, 06:08 PM   #5
omg A e46
My Ride: 323i
Damn **** that you can paint them your self for under $50 for all 4 and it will look hella nice if you do it right
omg A e46 is offline   Reply With Quote
Old 12-27-2012, 06:15 PM   #6
Goondaddy
My Ride: 2002 325ci
Hella go away.
Goondaddy is offline   Reply With Quote
Old 12-27-2012, 09:06 PM   #7
f4n4tik
Powder coated
Transport? Why didnt you just get them done locally ? Are you happy with how they turned out?
Old 12-27-2012, 09:48 PM   #8
BMW E465
My Ride: 1dirty5
$100 per wheel, sandblasted and powdercoated in two layers, from Mr Kleen in Sydney. $75 for 18"
BMW E465 is offline   Reply With Quote
Old 12-27-2012, 10:00 PM   #9
Commando
My Ride: '02 325Ci MT '04 M3
I powdercoated some wheels silver/grey then had a powdercoat clear over the top - this improves the finish and looks as glossy as enamel or 2-pack and provides some degree of protection. There are mobile guys that will come to you and paint the wheels presumably not powdercoat. Powder coat is tough but if it does get a chip in it these can grow as water/corrosion gets between the finish and the underlying metal.
Have a look at the finish called shadow chrome. Looks nice IMHO. Although this depends what the body colour is. Presumably you don't want to look like some riced out rollerskate.
Costs about 100/wheel - more for clear or shadow chrome.
Commando is offline   Reply With Quote
Old 12-27-2012, 10:22 PM   #10
YGOAMG
Bought the wheels in sydney.
Transport to melb straight to powdercoater
Got powder coater to transport to tyrepower so I could get tyres fitted
@PeterMarquez346
who da F done that?
Old 12-27-2012, 10:31 PM   #11
stevenluczynski
My Ride: Is Steel Blue
Originally Posted by Goondaddy View Post
Hella go away.
stevenluczynski is offline   Reply With Quote
Old 12-27-2012, 10:34 PM   #12
f4n4tik
Anyone know of any good places to get wheels powder coated and sandblasted on the Gold Coast?
Old 12-28-2012, 01:28 AM   #13
MRBMR
My Ride: E46 R32 GTR
Just diy'd mine with enamel paint & primer with a clear coat aswel cost me $70 all up, slow process doing it yourself but saved a fair bit of coin w/out compromising too much on quality.. Went from gunmetal grey to white, turned out pretty sweet
MRBMR is offline   Reply With Quote
Old 12-28-2012, 01:59 AM   #14
f4n4tik
Attachment 483705
Looks good man! Did you buy a spray gun for this? Where did you get the paint from? If you can be bothered, could you give me like a brief outline on what's involved.
Old 12-28-2012, 02:35 AM   #15
steve.k
1 can of color for each wheel + 2 cans of clear + 2 cans of primer. Mask up around wheel, wet sand first with 400-600 then smoothen with ultra high grit (1000+) until very smooth. Use a paint surface cleaner (degreaser) to clean after sanding. Primer 2 coats, paint 2-3 coats, clear 2 coats. Wait minimum half hour between coats. If you want to be very anal you can also lightly wet sand with very high grit in between coats (when dry).
Old 12-28-2012, 02:51 AM   #16
rodsfromday
My Ride: 323CI
I initially wanted to also powdercoat my E30 rims but decided to spray them myself instead. As MR was saying its a rather slow process. I took about a week with them. Each primer'd and 3 coats gloss black. Finally a couple of layers of clear coat. Well worth it in the end.
German Engineering at its best
rodsfromday is offline   Reply With Quote
Old 12-28-2012, 02:57 AM   #17
11EAS
My Ride: M3
Hey, I used Depulu Wheels down on the GC to fix my scratched up/scuffed wheels and repaint black when I had my 2 piece wheels on my ol Rotary. Cost 800 or so for all 4, took them a couple of days. Highly recommend them.
'04 JB/IR M3
11EAS is offline   Reply With Quote
Old 12-28-2012, 04:49 AM   #18
MRBMR
I basically followed exactly what stevie.k said, bought everything from supercheap auto... Spent a day on each wheel as I don't have a spare set of wheels & was using the spare to get around in, I followed a DIY I found off another forum & it worked out good just takes plenty of patience..
Old 12-28-2012, 07:38 AM   #19
f4n4tik
You wouldn't still have the link bookmarked? $70 sounds heaps better then like $5-600
Old 12-28-2012, 07:50 AM   #20
niiCk
My Ride: E90
painting would be pretty easy..pretty much do what Steve said..but instead of degreaser, i would use wax and grease remover.
Also i dont use a clear coat ontop..really depends on what paint youre using. If you use a spray gun, would be so much better and easier.
niiCk is offline   Reply With Quote
