///M3 Forum
Old 03-17-2015, 04:13 AM   #1
iansevilla
My Ride: 2004 M3 Coupe
Compression Spring Plug
Anyone knows how to fix a small leak on one of the compression spring cover in the transmission? Should just put some luiquid seal and cover it? Trying to stop slow leak? Is it hard to fix the plug while tranny is in the car?
iansevilla is offline   Reply With Quote
Old 03-17-2015, 12:21 PM   #2
iansevilla
Just curious if this can be done without taking the tranny down. Thanks in advance.
Old 03-20-2015, 11:29 AM   #3
iansevilla
Bump
Old 03-20-2015, 02:06 PM   #4
KT22cliffjumper
My Ride: 2005 M3
If you are talking about one of these plugs below then it's "doable" without taking the transmission out but it is royal pain in the ass to pop them out AND put the new plugs back in. I have no idea whether some liquid seal can seal any leak coming from the plugs.
http://www.m3forum.net/m3forum/showt...spring+SMG+DIY
2005 silver gray | SMG | Xenon | sunroof delete | manual nappa leather/cloth seats | TC Kline D/A Coilover 450F/500R with TCK camber plates and TCK RSM | BMW Motorsports 4.10 LSD | Powerflex RTAB | BBS RS-GT 18"
KT22cliffjumper is offline   Reply With Quote
Old 03-20-2015, 03:44 PM   #5
iansevilla
Thanks. I lost more than half a quart of pentosin since November after seal in tranny was worked on. I had it filled with silicon to see if it will stop leak. I hope it stops the leak coz my next clutch replacement won't be anytime soon. Clutch was replaced 13k ago. But if leak doesn't stop. I may need to have the tranny taken out. :-(
Old 03-20-2015, 05:16 PM   #6
KT22cliffjumper
My Ride: 2005 M3
Do you know which plug is leaking? Some are slightly easier to get to than others. The location of the plugs and the lack of the space around them just make it very difficult to put any kind of leverage to pop them off AND just as hard to put them back in.
Good luck whether you go liquid seal or plug replacement route.
Old 03-20-2015, 05:22 PM   #7
iansevilla
Yes, found the front lower plug seal leak. Filled it with liquid seal to see if it will fix it. Well, filled both of them. This tranny was converted from SMG to Manual last year. I'll check tranny for leak next week.
Old 03-21-2015, 04:34 PM   #8
iansevilla
This is my leaking tranny...lolClick image for larger version
