Australia
Check out other E46Fanatics members rides in the Enthusist Directory! If you don't have your garage setup, sign up today HERE |
#1 |
Powder coating
What is a fair price for a gloss black powder coat on a set of 19" wheels, or even painted ??
Thanks |
#2 |
'Painted' - I presume you mean Wet Spray Vs. Powdercoating. Powdercoating around $100-200 per rim depending on where you go and what colour you want done, wet spray roughly the same. Powdercoating will give far better durability over wetspray although wetspray in some instances will provide a better finish.
#3 | |
#4 |
My Ride: 325Ci ClubSport
I got mine done for about $190 per wheel. + transport
Powder coated
#5 |
Damn **** that you can paint them your self for under $50 for all 4 and it will look hella nice if you do it right
#6 |
#7 |
#8 |
$100 per wheel, sandblasted and powdercoated in two layers, from Mr Kleen in Sydney. $75 for 18"
#9 |
I powdercoated some wheels silver/grey then had a powdercoat clear over the top - this improves the finish and looks as glossy as enamel or 2-pack and provides some degree of protection. There are mobile guys that will come to you and paint the wheels presumably not powdercoat. Powder coat is tough but if it does get a chip in it these can grow as water/corrosion gets between the finish and the underlying metal.
Have a look at the finish called shadow chrome. Looks nice IMHO. Although this depends what the body colour is. Presumably you don't want to look like some riced out rollerskate. Costs about 100/wheel - more for clear or shadow chrome. |
#10 | |
Transport to melb straight to powdercoater Got powder coater to transport to tyrepower so I could get tyres fitted |
#11 |
![]() I code cars-p'm me |
#12 |
Anyone know of any good places to get wheels powder coated and sandblasted on the Gold Coast?
#13 |
Just diy'd mine with enamel paint & primer with a clear coat aswel cost me $70 all up, slow process doing it yourself but saved a fair bit of coin w/out compromising too much on quality.. Went from gunmetal grey to white, turned out pretty sweet
#14 | |
#15 |
1 can of color for each wheel + 2 cans of clear + 2 cans of primer. Mask up around wheel, wet sand first with 400-600 then smoothen with ultra high grit (1000+) until very smooth. Use a paint surface cleaner (degreaser) to clean after sanding. Primer 2 coats, paint 2-3 coats, clear 2 coats. Wait minimum half hour between coats. If you want to be very anal you can also lightly wet sand with very high grit in between coats (when dry).
#16 |
I initially wanted to also powdercoat my E30 rims but decided to spray them myself instead. As MR was saying its a rather slow process. I took about a week with them. Each primer'd and 3 coats gloss black. Finally a couple of layers of clear coat. Well worth it in the end.
![]() German Engineering at its best |
#17 | |
![]() '04 JB/IR M3 Last edited by 11EAS; 12-28-2012 at 01:59 AM. |
#18 |
I basically followed exactly what stevie.k said, bought everything from supercheap auto... Spent a day on each wheel as I don't have a spare set of wheels & was using the spare to get around in, I followed a DIY I found off another forum & it worked out good just takes plenty of patience..
#19 | |
#20 |
painting would be pretty easy..pretty much do what Steve said..but instead of degreaser, i would use wax and grease remover.
Also i dont use a clear coat ontop..really depends on what paint youre using. If you use a spray gun, would be so much better and easier. |
