Complete Cars
List your BMW or other cars, trucks or vehicles for sale. Don't forget to search for deals on craigslist and eBay Motors |
#1 |
FS: 1998 M3/4/5 with 91,000 miles
I have a 1998 M3/4/5 for sale. It is black on dove interior. The car has 91,000 miles on it and I have owned it since 2010 when it had 68,000 miles. The car is in great shape overall and I love it; I just have the itch to get an E46 M3. First of all I tapped a car infront on my at a light and had the bumper and left headlight replaced by a local shop in the area. Everything was professional and cant even tell it happened (Damn rush hour traffic) It has Broadway Static coilovers as well. I just changed the cooling system installing a new Geba water pump, thermostat, thermostat housing and new coolant in. The AC/heat both work very well. Has a CD43 with a DICE routed through the sunglass holder which allow you to use your iPod and see on screen text. It only three small issues, one is there is a tiny amount of rust on the driver side rear fender. It is very small in size and I was told it could be fixed easily. The other issue is that I took out all the pillars and headliner in order to get them reupholstered since the headliner, but the headliner cracked during transport. I have all the screws, lights and pillars, just not the fiberglass headliner board and last is the rear driver's side for handle doesn't work from the outside. It works perfectly fine from the inside. I rarely have passengers in the back so it was never an issue for me. It should be easy to find one and then you can get it done in any material that you fancy. I also have a set of AC Schnitzer's Type 1 that can go with the car as well.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() $12,900 with the wheels $10,900 with stock wheels Last edited by blackbmuum3; 11-26-2012 at 09:34 AM. |
#2 |
My Ride: my favorite two feet
in for pics
#3 |
For some reason it wouldn't allow me to post everything via mobile. Here is the link from bimmerforums.
http://forums.bimmerforums.com/forum....php?t=1909994 Sent from my SPH-L900 using Bimmer App |
#4 |
#5 |
Pictures added.
#6 |
Interested?
#7 |
Bump
#8 |
Ttt
#9 |
Define "tap" to the front of the car that had to have parts replaced, is it a clean title and do you have before to go with the after pics?
#10 |
I was at a stop light and let the clutch out before the light turned green and bumped into the civic infront of me. If I recall the right headlight cracked, along with cracked the front bumper. I can look at the service bill of the shop that fixed it and let you know what all was replaced. I dont have before pictures of the accident if thats what you mean. Nothing changed on the car other then replacing the damaged parts.
#11 |
Bump to the top
#12 |
Wednesday Bumpage
#13 |
Interior fabric was ordered and should have all the interior pillars and shuttle covered on Friday. Squeaking noise was eliminated when I pulled the AC belt. I ordered a new pully and should be good to go on that one. I recently got a CEL light on about the O2 sensor. They are relatively new so I cleaned them off and reinstalled and cleared the code to see if it comes back. Car should be ready to go by this weekend.
Sent from my SPH-L900 using Bimmer App Last edited by blackbmuum3; 12-12-2012 at 09:43 PM. |
#14 |
Interior is done.
#15 |
Bump
#16 |
ttt
