Sponsored by BimmerWorld
Old 12-28-2012, 10:53 AM   #1
xrb
My Ride: 325xi
Brake pad warning light still on after new pads?
So the brake pad warning light came on a week or so ago and I knew the rear pads were getting thin so I replaced the pads and put new rotors on as well since they were pretty worn. When removing the sensor from the passenger side pad I broke it so I got a new one and replaced it also.
So all goes back together and the warning light is still on. Do I need to reset something to get this to go off?
xrb is offline   Reply With Quote
Old 12-28-2012, 10:58 AM   #2
teamdfl
Slow in, slower out
My Ride: 325it
Turn the key to position 2 but do not start the car. Leave it there for 30 to 60 seconds and the pad warning light should turn off.
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
Old 12-28-2012, 10:59 AM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
^ Bingo
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 12-28-2012, 01:23 PM   #4
xrb
My Ride: 325xi
Thanks guys! My first BMW- it's actually my daughters.
Old 01-18-2013, 09:34 PM   #5
luisimo
My Ride: 2000 323i wagon
My first BMW also and I had the same problem with my 2000 323i wagon. I did the same thing as suggested by "teamdfl" and the light disappeared. Thanks
Hey "xrb" how did your brake job go? My brake job feels hesitant, I got Zimmermann rotors by "FCP" error (intended to be Brembos) and Textar pads. They told me they were slightly better quality as they are coated with anti-rust and had holes for heat release, but they feel hesitant not that sharp bite as those removed. Is this normal as new brakes get broken into? I am a little worried to had stayed with those Zimmerman rotors.
luisimo is offline   Reply With Quote
Old 01-19-2013, 08:24 AM   #6
xrb
My Ride: 325xi
I put ceramic pads on with new Meyle rotors. I did bed them in and before I did, they didn't have much bite. So if you used ceramic pads (and many others I suspect) you need to do a little bedding to get them to work properly. Otherwise, all is good.
Hope this helps.
