Sponsored by BimmerWorld
Old 12-28-2012, 04:05 PM   #1
kmalik20
My Ride: Bmw 325i
What brakes are good
2004 BMW 325i
Looking to replace the brakes and rotors
Should I get Ceramic or Semi-metalic
Also what is a good brand
I am looking at the:
1. Wagner Thermo Quiet Semi metalic/ and ceramics
2. Wagner Quick Stop Semi Metalic/ and ceramic
3. Beck/Arnley Semi Metalic/ or ceramics (Apparently they are the same brand of Zimmerman)
4. Raybestos professional grade semi-metalic
What are your inputs, I am a daily driver. Perhaps someone has some experience with some of these brakes.
kmalik20 is offline   Reply With Quote
Old 12-28-2012, 04:13 PM   #2
My Ride: Lexus
stock
Old 12-28-2012, 04:24 PM   #3
Zell
Zell's Avatar
My Ride: so turbo wow
EBC RedStuff. EBC makes great brake parts. Their quality control is really up there.
Old 12-28-2012, 04:26 PM   #4
My Ride: Lexus
last time i installed ebc green stuff brake pads and ebc slotted rotors, i nearly crashed. they overheated drastically (driving very mildly on the street) when the fluid boiled and pedal sank all the way to the floor. This was 10 years ago on my 2002 civic (brand new civic) so i'm not sure if their stuff is better now.
Old 12-28-2012, 04:33 PM   #5
7xWDC-MSC
My Ride: 2005 325xi
I replaced mine with Padgid and love them, they aren't as dusty as OEM but still dusty. I believe OEM is Textar though if you wanna go that route.
7xWDC-MSC is offline   Reply With Quote
Old 12-28-2012, 04:36 PM   #6
BMW#3
Banned User
My Ride: Jet Black 330ci
Stock is always good. Or if you want to spend some extra money the bmw performance rotors are a little bit lighter and slotted. I have a set with stock pads and if nothing else they look good.
BMW#3 is offline   Reply With Quote
Old 12-28-2012, 05:32 PM   #7
FenderGuy05
My Ride: 2002 BMW 325i
I wanted to keep the stopping power so avoided ceramics. I went with Akembo pads I believe, and brembo rotors. From what I understand that's OEM.
FenderGuy05 is offline   Reply With Quote
Old 12-28-2012, 05:37 PM   #8
rcsummers
My Ride: M3
i have stoptech drilled/slotted rotors, akebono pads, motul red fluid. Slightly better braking performance than stock for me. but then again I have an M.
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 12-28-2012, 05:39 PM   #9
My Ride: Lexus
Nope. Both aftermarket companies.
You meant Akebono, btw.
Old 12-28-2012, 05:47 PM   #10
rcsummers
My Ride: M3
BMW parts would be OEM.
"RICH"
My Build Thread
EURO.TECHNIKS
Old 12-28-2012, 05:48 PM   #11
My Ride: Lexus
BMW parts would be OE.
BMW parts with the roundels scratched off and/or identified by an OEM supplier would be OEM.
Old 12-28-2012, 06:36 PM   #12
Zell
Zell's Avatar
I've been told to stay away from GreenStuff as well, but RedStuff seems to be the sweet spot.
Old 12-28-2012, 06:43 PM   #13
tock172
My Ride: '12 135i Dinan S2
I'm running Zimmermann Rotors & Ate pads. If I were to do it all over again, I would get Ate rotors & textar pads or jurid pads.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 12-28-2012, 06:57 PM   #14
My Ride: Lexus
i love the brembos except the rusting. sholud have painted it or gone zimmerman since i think they are coated. dont like the zimmermans?
i'm using ate pads front, textar pads rear.
Old 12-28-2012, 07:01 PM   #15
tock172
The zimmermann rotors are excellent. Absolutely no complaints. No rusting problem either.
I have reason to believe the OE rotors are actually manufactured by Ate, so what's why I'd probably go Ate next time. I feel they might be cheaper as well by a few dollars.
Old 12-28-2012, 07:06 PM   #16
BBBoy323i
My Ride: 01' 325ci
I have the same setup as you for my fronts they are pretty good.
BBBoy323i is offline   Reply With Quote
Old 12-28-2012, 07:15 PM   #17
My Ride: Lexus
IIRC, the Ate and Genuine BMW rotors look different. I don't think any other branded rotors match the dark gray look of the BMW ones. While ATE might make a lot of OE brake components for BMW, not 100% sure about the rotors. check it out
Old 12-28-2012, 07:53 PM   #18
E46330iguy
My Ride: Supercharged 330i
I run Stoptec Rotors and pads, They work great for the track but they are a bit noisy. If your 100% street use just go stock
Winter Authority When Hell freezes over,we'll play Hockey there too
you've Met a terrible fate haven't you ?
KONI /Michelin/Stoptec/Borla/ Bimmerbrake / MTechII/AA Stage one (for now) Automatic--->5 speed swap/ UUC High performance clutch kit
Questions about Header wrap? clickHere
Supercharger build thread click Here
E46330iguy is offline   Reply With Quote
Old 12-28-2012, 07:54 PM   #19
sfcjetjr
Bmw oem. Dust yeah, but comes with the territory. Stop trying to fight it. Look at every other European car, same issue.
sfcjetjr is offline   Reply With Quote
Old 12-28-2012, 07:57 PM   #20
E46330iguy
To give you an idea on the dust that comes off my stoptec rotors/pads, My rims where perfectly clean before i went to take that picture, I drove maybe an hour and they looked like that.
