Old 12-28-2012, 09:59 PM   #1
louiecat
My Ride: 2000 Bmw 323ci
Does anybody know about 4L30E AOD Transmission Pump replacement?
Any help on 4L30E AOD Trans pump and parts
louiecat is offline   Reply With Quote
Old 12-28-2012, 11:53 PM   #2
HakenTT
My Ride: 323i with S54
It is cheaper to buy used transmission than to gather parts. Pump is $200, seal kit is $150, not worth it.
HakenTT is offline   Reply With Quote
Old 12-29-2012, 12:42 AM   #3
louiecat
Thank You I need all the advise I can gather.
Old 12-29-2012, 12:33 PM   #4
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Be more specific on what you need and why.
Sure you can get the parts. What do you want to do.
BMWCaptain is offline   Reply With Quote
Old 12-29-2012, 07:23 PM   #5
louiecat
Hello Captain, I am not familiar with using this form, But what has happened is a friend of mine helped me replace the motor in my 2000 323ci and he did not set the converter all the way in therefore I believe the pump in the trans was damaged, the car will not move forward or reverse and I was told has no line pressure, I am having some bad luck but I am not giving Up. I was fortunate to find a low mileage motor and then this happens, I have been looking around at used Trans and don't know if I am better off just having my Trans rebuilt. any suggestions Please comet. Thank You Bill.
Old 12-30-2012, 01:51 AM   #6
BMWCaptain
You should contact, flashtwosix on this forum because she has experienced this exact problem with her transmission on an engine change.
Do you have the 5L40E 5 speed GM Automatic?
Old 12-30-2012, 06:35 PM   #7
louiecat
I believe it's a 4L30E 5 speed Automatic and the Tag on the trans does say GM , How do you contact someone on this form?
Old 12-30-2012, 11:38 PM   #8
BMWCaptain
You probably have the GM 5L40E in your 2000 323ci.
Send a private message to the member. Select User CP at the top, then select Send Private Message.
