"Light Out" warnings and Marker Light - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-07-2013, 03:53 PM   #1
nskill01
My Ride: 330Ci
I have a 2001 330ci and for some reason both of the tail brake light out indicators have been on for quite some time, however the tail lights/tail brake lights are in working order. They are LED but do they have a ground somewhere that might be going off? Does anyone have any suggestions for this? Also, my marker light has gone out, and when i attempt to replace it with another light, nothing happens still. These are unrelated events to the best of my knowledge but it does seem like some sort of electrical problem.
nskill01 is offline   Reply With Quote
Old 02-07-2013, 06:25 PM   #2
azshorty
My Ride: Hellrot 323CI
I believe when converted to l.e.d lighting, there is a resistor that might need to be installed. On the other hand, check your license plate bulbs. I had the same issue and turned out to be license plate bulbs.
azshorty is offline   Reply With Quote
Old 02-07-2013, 07:04 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 340K miles
...and reversing light...and if needed, which it probably will be, search for me and my thread with "elephant trunk" in the title. Bet your issue is there...or just license or reverse light bulbs needed.
GL
Appearing Friday, Jan. 13 at Greenwich Village Comedy Cub, 99 Macdougal St., NYC, 6 p.m.
dmax on Facebook
Mangofy your E46!
Sponsored Links
Advertisement
Old 02-07-2013, 07:25 PM   #4
jdstrickland
My Ride: '94 325iC & '00 323i
The LEDs are a problem.
Not a _real_ problem, but the car expects there to be resistance on the circuit, but the LEDs have no resistance so what the car expects does not exist, and there is a message to tell you this.
Old 02-07-2013, 07:28 PM   #5
jdstrickland
For the side markers SWAP THE ONE THAT WORKS TO THE LOCATION OF THE ONE THAT DOES NOT WORK. If you replaced a broken bulb with another broken bulb, then you have no clue what's going on. If you have a light that you KNOW works, and it does not work when you move it, then you learn something. If you have a bulb that does not work in one place, but works in another, then you also learn something.
HINT
The fuses live in a fuse box that's located above the glove compartment.
