E46 Convertible
Old 12-29-2012, 11:55 AM   #1
Ziggy 10
My Ride: BMW 330ci CON
ACS light
Hi im new here....my ACS light on my dash is staying on...can someone please tell what the problem is Thanks
Ziggy 10 is offline   Reply With Quote
Old 12-30-2012, 12:37 AM   #2
Nickvjr
My Ride: 2004 330Ci Conv.
Send a message via AIM to Nickvjr Send a message via Yahoo to Nickvjr
Folks are going to need more than that if you would like someone to help you... Also you should try the 'search' function in the forum and read as much information as possible and you might just solve the problem yourself.
It could be something as simple as a button being pressed below the radio that deactivated the system (at least I believe that is how the DSC worked on my E46), wiring problem, brake module problem, etc.
Have you tried anything to make the light turn of? Restarted the car? When did the light come on... were you driving... were you parked... etc.
This type of info may help someone that has had a similar problem to yours lead you to a solution. Good Luck!
-Nickvjr
2004 BMW 330Ci Convertible
Nickvjr is offline   Reply With Quote
