Old 12-29-2012, 04:43 PM   #1
alvin bryan lim
My Ride: 330ci
at wits end on P0171 & p0174
hey there guys i need help on my current problem. i'll make this as simple to read as possible just because i hate reading large paragraphs as well.
* pulled codes P0171 and P0174
- replaced: intake rubber boot
- vent pipe
- return pipe
- tube elbow
- cleaned MAF
- replaced air filter
- replaced gas cap
(no rough idle, but alittle loss of power)
= results is SES still on, MPG meter (below tachometer) goes up to 20 or more right before stopping. gas is killing me
*** i''m going to clean the throttle house assembly today, just as soon as it stops raining.
I need help guys!
king kong ain't got nothing on me!
Last edited by alvin bryan lim; 12-29-2012 at 04:46 PM. Reason: need to put that important part in there
alvin bryan lim is offline   Reply With Quote
Old 12-29-2012, 06:02 PM   #2
SHK&BAK3
My Ride: rustles jimmies
replace your adjuster also called ICV fixed my 171and174 codes bought the part online for 218 shipped. I tried all of what you listed and this was what fixed my problem
SHK&BAK3 is offline   Reply With Quote
Old 12-29-2012, 07:24 PM   #3
alvin bryan lim
My Ride: 330ci
thanks for the input shake&bake.
This is what just happened; finished cleaning my ICV, tested DISA or Adjuster unit (still works). SES still persist.
MPG meter still goes up, but just below 20 MPG right before coming to a complete stop. (slight improvement)
kill me now please!
Old 12-30-2012, 11:51 PM   #4
Brobby87
My Ride: 2003 325i, 1986 535i
- vent pipe
- return pipe
- tube elbow
- cleaned MAF
- replaced gas cap
I need help guys!
Does this mean you replaced the tubing to the CCV? I had those codes for a long time until I replaced the CCV and all it's respective hoses.
Brobby87 is offline   Reply With Quote
Old 12-31-2012, 09:14 AM   #5
markusmarkus
My Ride: 2001 330Ci
To follow up on Brobby, did you change the upper AND the lower intake hoses? Are you sure that the lower hose was properly aligned?
Old 12-31-2012, 09:40 AM   #6
upanddown
My Ride: 04 352i
After having same issue and performing the same service as you have, it came down to changing the CCV and the adjoining hoses. It was not an easy job but there is a 4 part youtube series on how to do the job that is priceless. Parts can be bought in a kit with all the needed parts and gaskets just for this common issue for $150-$200 if memory serves me right.
upanddown is offline   Reply With Quote
Old 12-31-2012, 06:01 PM   #7
markusmarkus
My Ride: 2001 330Ci
+1!
Happy New Year!
Old 01-01-2013, 05:44 PM   #8
alvin bryan lim
My Ride: 330ci
Thanks for all the input. But I've done all that when I first brought it to a shop. It's is what they replaced;
Oil separator(CCV) part # 11617501566
Breather hose(return pipe) part # 11617504536
Breather hose(vent pipe) part # 11611432559
Oil breather(vent hose) part # 11157532649
new codes came up; P0102 and P0113 this is ontop of the P0171 and P0171.
I tried to locate the intake air temparature (IAT) but couldn't find it. some people say its the same unit as the MAF.
I bought a cheap MAF from ebay about $100.00 but made it worst so i took it out and put my old MAF in.
any recommendations? i'll listen to anything short of setting this damn thing on fire.
cheers HAPPY NEW YEAR!!!!!!
Old 01-01-2013, 09:08 PM   #9
upanddown
My Ride: 04 352i
Do you have any oil leaks?
Old 01-01-2013, 11:05 PM   #10
jaswild
My Ride: 2005 BMW 325i
Ugh you are scaring me I have the same issue right now. I had taKen my car in to have them check and they said they found cracked caps on the spare vacuum ports below the cab filter had dried and cracked. Something else to possibly look at.
jaswild is offline   Reply With Quote
Old 01-01-2013, 11:06 PM   #11
jaswild
I will need to pay attention to this thread as I feel like I will be going though the same steps.
Old 01-03-2013, 09:48 AM   #12
Big Geek
My Ride: 2001 325i
Check fuel pressure, especially if the SES light comes on while driving. Weak fuel pump or dirty filter can cause lean codes.
Big Geek is online now   Reply With Quote
Old 01-05-2013, 02:25 AM   #13
alvin bryan lim
My Ride: 330ci
No oil leaks and I just finished changing the fuel filter. I think it's the MAF since another code came up. P0102 and P0113
Old 07-03-2013, 12:59 AM   #14
E40SICK
My Ride: 2001 330ci
any updates on this?
E40SICK is offline   Reply With Quote
