Old 12-30-2012, 01:28 AM   #1
ScouseYank
My Ride: 2001 325ci coupe
Yellow Brake light and Triangle with ! with Circle
Ok, so bought i used bmw and have had a few issues of which a quick search on here has found the right fixes, one thing i have searched for and cant really geta clear answer for is that when i start the car, there is a yellow brake light on as well as the triangle with the ! with a circle, all the searching has done nothing as i could not find anyone else with the same problem,
any help would be great,
ScouseYank is offline   Reply With Quote
Old 12-30-2012, 01:30 AM   #2
eneka
My Ride: 2003 325i
something is wrong with DSC
eneka is offline   Reply With Quote
Old 12-30-2012, 01:48 AM   #3
ScouseYank
ok, so what would one do ? take it to a shop?
is this something i could fix my self?
also pushing and holding the dcs button for 3-30 seconds does nothing
Old 12-30-2012, 02:07 AM   #4
eneka
My Ride: 2003 325i
you need to diagnose it, it could be anything. Check the fuses, take it to an indy or someone that has a BMW scanner and they can pull codes and tell you exactly what's wrong.
Old 12-30-2012, 02:21 AM   #5
mcr_driver
My Ride: my favorite two feet
you could try the stomp test and see if you get any codes from that if not, try the basics like unplug the battery for 30-60 minutes then repeat stomp test and see if any new codes come up. Agreed on checking the fuses as well after doing the code test. If possible use a code reader but if you don't that's a good place to start
mcr_driver is offline   Reply With Quote
Old 12-30-2012, 09:54 AM   #6
zhenkaaaM3
My Ride: Fst'r then your e46
Its either a steering angle sensor or a wheel speed sensor.
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 12-30-2012, 10:04 AM   #7
chrism24
My Ride: 2002 325i
Have you tried just pressing the DSC button once and releasing it immediately?
chrism24 is offline   Reply With Quote
Old 12-30-2012, 10:16 AM   #8
BMW#3
Banned User
My Ride: Jet Black 330ci
It was the steering angle sensor for me. Fastest thing to do like people have said is to go get it scanned by an indi, or if you're suicidal by the dealer. The steering angle sensor was fairly expensive from what I remember. Good luck!
BMW#3 is offline   Reply With Quote
Old 12-30-2012, 10:33 AM   #9
Sh0ty
My Ride: 2001 M3, 2004 330Ci
The steering angle sensor (SZL or SLZ, can't remember) was around $1000 when I was pricing it for an E90, to give a ballpark.
2001 ///M3 - Carbon Schwarz
2004 330Ci - Titansilber Metallic
2007 328i - Titansilber Metallic
Sh0ty is offline   Reply With Quote
Old 12-30-2012, 10:44 AM   #10
BMW#3
Banned User
Yea, I don't think I walked out of there for less than $750.
Old 12-30-2012, 11:32 AM   #11
RayPooley
My Ride: 320i SE Coupe
Like this? This indicates that the DSC is switched off. Normally on by default and you need to hold the DSC button down fro three seconds to switch it off. If these lights are on by default may indicate dirty wheel speed sensors or faulty ones, a malfunctioning steering position sensor and so forth. Start with cleaning wheel sensors. That's a cheap and easy place to start. Take a look at the attached PDF for more info on the components involved. Also press your DSC button see if the go out and then come back on again. I should also say that this happened a month or so ago when I had a faulty crank position sensor which caused my car to stall momentarilly while on the move. These lights came on and stayed on until I switched of the ignition. The lights don't mean that you can't drive the car by the way.
Old 12-30-2012, 11:36 AM   #12
darksideracer69
My Ride: 01 325ci
Don't start anywhere with out getting the codes read first. You'll just waste time and money ****ing around.
Sent from my PC36100 using Bimmer App
IMAG02051
Old 12-30-2012, 11:43 AM   #13
BMW#3
Banned User
Bam! He speaks the truth!
Old 12-30-2012, 01:07 PM   #14
SidewaysBimmer413
My Ride: 2002 325i Auto
Correct me if i am wrong but is the ! with the Circle around it just the traction control? the DISC button just needs to be pressed for a second or so to turn it off and on.
SidewaysBimmer413 is offline   Reply With Quote
Old 12-30-2012, 01:11 PM   #15
BMW#3
Banned User
If evrything is working properly that's true but combined with the yellow brake light it means you've got a more serious problem like the ones above.
Old 12-30-2012, 01:14 PM   #16
sweetbro858
Banned User
My Ride: BMW
Could be thinking of different dash light, but one would come on all the time driving in the snow. Snow got stuck up all in the brakes and by that sensor...
sweetbro858 is offline   Reply With Quote
Old 12-30-2012, 02:27 PM   #17
RayPooley
Speed sensors work by detecting changes in magnetic flux density as rotating elements move in and out of the sensor's magnetic field. They are basically permanent magnets with a coil wrapped around them. Anything that interferes, obstructs or bridges the normal gap between the magnet and the rotating element (eg: snow, mud) can have an impact on the voltage of the pulses received by the DME which, in turn, can be interpreted as fault resulting in automatic shutting down of DSC as precaution. So check the cleanliness and integrity of the wheel sensors first.
Old 12-30-2012, 02:33 PM   #18
TrickTizzle
My Ride: 325i
Bad wheel speed sensor.
Scan the car to see which is throwing error and clean it with a wire brush. Might as well clean all of them while your at it. If cleaning doesn't work just replace the sensor. Takes 5 min .
Old 12-30-2012, 02:41 PM   #19
sweetbro858
Banned User
My Ride: BMW
It's like you took the words right outta my mouth
What I meant was, when snow got packed up in my brakes, the light would sometimes come on and then go off when it was clear again.
Old 12-30-2012, 10:14 PM   #20
E46LR
My Ride: E46
If is the steering angle is about $300 in E90 the SZL brings the steering angle that is the reason of the price $1,000
E46LR is offline   Reply With Quote
