Old 12-30-2012, 09:35 PM   #21
FlashBMW
My Ride: 2009 328 Xdrive
Had the same problem for 2 months.
I cleaned the both sensors on the rear and cleared and reset everything on the xbox 1.4 scanner and it worked fingers crossed.
FlashBMW is offline   Reply With Quote
Old 12-30-2012, 09:43 PM   #22
TitanSl33pr
My Ride: 330ci
Aside from the wheel speed sensors, check ur vacuum pressure fitting and/or hose going to the brake booster. A vacuum leak there will shut the DSC off as well. I found that out after cleaning then replacing all of my wss on my previous 330ci.
Sent from my SPH-L710 using Bimmer App
TitanSl33pr is offline   Reply With Quote
Old 01-01-2013, 11:17 PM   #23
ScouseYank
My Ride: 2001 325ci coupe
Originally Posted by TrickTizzle View Post
Bad wheel speed sensor.
Scan the car to see which is throwing error and clean it with a wire brush. Might as well clean all of them while your at it. If cleaning doesn't work just replace the sensor. Takes 5 min .
thanks for the info, im not a mechanic, but i do have a bit of smarts,
is there a guide online to cleaning those that you know of?
thanks
ScouseYank is offline   Reply With Quote
Old 01-02-2013, 03:26 AM   #24
RayPooley
My Ride: 320i SE Coupe
thanks
Check this out. It gives you an idea ...
http://www.bmwfanatics.co.za/showthread.php?tid=17759
