E46 Xi Forum
Old 12-30-2012, 04:44 AM   #1
Twin_Turbo_S54
My Ride: M3
LSD in front differential
can we install LSD into XI front diff?
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 12-30-2012, 01:43 PM   #2
Kubica
My Ride: 2003 325xi
Better off trying to make the TC into limited slip. I've been told it's possibe to put an LSD up front, however. I was also told it would cause more understeer. Modifying the TC is probably a better option. You could most likely make an e90 TC fit, but wiring that unit up to an e46 is way above my pay grade. Something I'm interested in though since it wouldn't change the class I run it at autox.
Old 01-01-2013, 09:01 PM   #3
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
I wonder if the e90 xdrive transfer cases bolt up or even fit under our cars
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 01-02-2013, 08:04 AM   #4
bikesandcars
My Ride: 2002 325xi-sport pkg
Can we? I tried a google search and didn't get any hits. If the front is the same as the rear you could probably find a LSD to fit. If not I doubt it as I didn't get any returns for that part.
Should we? Probably not. In the offroad world people don't usually run a LSD on the front differential in a street vehicle due to the understeer it creates and the handling issues that insue when fighting the rear wheels while turning. Many guys will install a manual locking differential up front so they can use it if they are stuck but leave it open during normal use... which begs another question
Which one would you use? There are basically 3 types (not counting spool/welding spider gears). Gear driven, Clutch/Plate type, or manual locking. Gear driven LS differentials (like Eaton's) seem much more popular in the import scene (not sure why over clutch / plate type), my guess is because they might work better with front wheel drive vehicles. If you can find one for the back and a back one fits the front you might be in luck. clutch would not be highly recommended I feel because it always provides some lockup and slips under load (vs the gear type that only provides lock under slipping torque). manually Locking would be best but I'm sure that's not available, never seen one for any imports
And why again? Why would you need this in a BMW, that is what the traction control system is for. In the winter it doesn't matter if your car uses the brakes to enhance traction. Just use the stock system IMO.
bikesandcars is offline   Reply With Quote
