Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 12-31-2012, 11:46 AM   #1
Mark M
My Ride: e30 M3 / e90 335d
Installed outlet in closets......
Random post here....nothing too elaborate.
I hate clutter. Definitely like organization.
I was tired of seeing my Braun razor / cleaner / charging station and electric toothbrush holder on the bathroom counter. Have a small linen closet in the bathrrom. Installed an outlet in the closet and now have those items living on the shelf in there. No more clutter - Win!
Same in the kitchen. Had the dust buster and stick vac causing clutter. Installed an outlet in the pantry closet and now those devices are tidy and out of the way - Win!
Mark M is offline   Reply With Quote
Old 12-31-2012, 06:58 PM   #2
Guest100615
Account closed per your request
Good idea. I have never considered that before.
Guest100615 is offline   Reply With Quote
Old 01-01-2013, 07:06 PM   #3
dynamictype
My Ride: 2012 BMW 535i
How hard was it to install? I am getting estimates this week for additional outlets.
dynamictype is offline   Reply With Quote
Old 01-02-2013, 11:28 AM   #4
SamDoe1
My Ride: 4cyl of fury
If you know how to work a circuit breaker, screwdriver, drywall saw, and a fish tape you shouldn't have any issues with doing this.
The closer another outlet on the string is to where you want a new one the easier it is.
Old 01-02-2013, 11:39 AM   #5
Mark M
I'm not afraid of electrical work. When I finished my basement I did all of the electrical myself.
In the case of these closet installs, I was very lucky. In both instances I had an outlet on the other side of the wall. One in a bedroom, another in the kitchen. So I simply had to cut a whole for a box and string the wire into the outlet on the other side of the wall in the same stud confines. Easy!
Old 01-02-2013, 10:28 PM   #6
dynamictype
Yeah in my case, the outlet is to far to the right and I wanted it in the center. The electrician said in that case he would have to remove the siding from the outside of the house and connect the new outlet to the old one that way.
Old 01-03-2013, 10:25 AM   #7
SamDoe1
How far is far? If it's less than ~6ft, you should be able to fish it through the walls using the existing power line holes that were drilled when the place was built. Other option, if this is on your top floor or you have ceiling access, is to go up into the attic/ceiling, over to where you want, and then back down the wall.
Old 01-03-2013, 11:24 AM   #8
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
Be careful when tapping into a kitchen, bathroom, basement, etc circuit that should be GFCI. You could compromise that safety feature
JonJon is offline   Reply With Quote
Old 01-03-2013, 12:34 PM   #9
poynter
My Ride: RAV4
Good point. is it 4 receptacles after the gfi that your allowed?
-tony
poynter is offline   Reply With Quote
Old 01-04-2013, 10:50 PM   #10
Guest100615
Am I correct that you can run a max of 6 outlets on one fuse ?
Old 01-04-2013, 11:05 PM   #11
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Probably a code or rule of thumb out there but if nothing is plugged in, you could have 3,000 outlets on one circuit
Wire gauge and breaker size is what's important with amp draw
Different rooms have different codes.
Generally I run an outlet every 5-6 feet. Kitchens, baths, basements need 12/2 20 amp circuits GFCI, regular rooms 14/2 15 amp. Blah blah blah
Old 01-05-2013, 01:34 PM   #12
Guest100615
Just curious...........would there be any benefit to running a higher gauge wire and putting 20 amps on every circuit just in case you ever needed the extra amperage ? Or would the extra amperage draw extra electricity and be an unnecessary expense ? It just seems like it would be a good idea to have the extra 'juice' so you would be less likely to have it trip.
Old 01-05-2013, 04:55 PM   #13
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
If nothing is plugged in, no amps are being "pulled" through the wires, hence nothing "wasted". Think of electricity as water and wires as pipes. Thicker pipes means nothing if no water is flowing through it
It's good to have 20 amp circuits run in the house now a days since typically more people are plugging things in and more often and at the same time and with higher amp devices
Zero downside besides a little extra cost
I ran pretty much everything in my house 20amp except for lighting
Old 01-06-2013, 10:12 AM   #14
tttomttt
My Ride: 2003 330xi
There are a few things to worry about when tapping into and existing outlet box. The first is wire fill. According to code the size of the box determines how many wires are allowed inside the box. Most new plastic boxes have the amt of wires written inside the box. A lot of older installations utilize all 4 screws on the outlet to continue down the line and feed other outlets. If you find this type of installation on the outlet you plan on using to feed another outlet you are going to have to change this configuration. After killing the power to the circuit remove the wires from the existing receptacle, noting the color of the wires. Twist (splice) these wires and the new feed color for color to continue the feed down the line. Cut a black, white, and ground wire approx. 8" long and terminate these to the previously removed outlet. Be sure to use the screws and hook the wire around them in a clockwise direction and tighten securely. Some outlets have terminations that allow you to skin the wire and push the terminations straight in the back (backstabbing), these terminations do not last and I get a lot of calls for faulty outlets because of this termination. On the other side of the outlet wires skin the insulation about an 1"-1 1/4 and splice onto the previously made splice so that all 4 respective colored wires are all teminated together. Once you complete all other work turn the circuit on and check for power at all locations. You can see how suddenly a outlet box can become full of wires pretty quick. Trust me nothing is ever as cut and dried as " I'll just tap into this existing outlet" there is generally something that will go array. There are GFI's (which may or may not present a problem) as previously stated as well as switched outlets where at least 1/2 the outlet is controlled by a wall switch. If anybody has any further questions you can PM me and I'll try and help you out.
Tom
tttomttt is offline   Reply With Quote
Old 01-06-2013, 10:22 PM   #15
Guest100615
I have seen some electrical boxes from Lutron that were 90 bucks a piece.
They are suppose to 'clean the electricity' and ground it better than a standard outlet you pay $1 for at HD.
Are they legitimate or is it just a gimmick ?
Old 01-06-2013, 11:51 PM   #16
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Lool
Old 01-07-2013, 12:27 AM   #17
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Ground it better...?
No that's not even a real thing.
Old 01-07-2013, 06:13 PM   #18
tttomttt
My Ride: 2003 330xi
Would love to see a link to this so that I can give you a possible explanation but it sounds like snake oil to me.
Old 01-08-2013, 11:59 AM   #19
Guest100615
I searched briefly but I could not find it.
I know that is what I read though....Lutron has some $ electrical outlets....
Maybe I can't find it anymore because they retracted it ?
Old 01-08-2013, 12:22 PM   #20
Guest100615
http://www.amazon.com/HUBBELL-DEVICE...rge+suppressor
