Old 01-01-2013, 02:40 AM   #1
dinan19
My Ride: 2004 Imola ZHP
Where are BB O2 Sims? (HELP)
Im about to order the bimmerbrakes headers for my 330, but i cant find them on the website anymore? Can someone tell me where to get them or if they are discontinued and need another simulator? Thanks.
Old 01-01-2013, 01:02 PM   #2
darksideracer69
My Ride: 01 325ci
I think they have been taken off the market, not 100% sure tho.
IMAG02051
Old 01-01-2013, 03:13 PM   #3
dinan19
Damn, yeah i wonder if its because they dont work. I think im gonna try the defouler mod and if that still doesnt work then just swap my stock manifolds back on for emissions time.
Old 01-01-2013, 03:19 PM   #4
darksideracer69
My Ride: 01 325ci
No is cause they are illegal Lmao. Only for off road use.
Sent from my PC36100 using Bimmer App
IMAG02051
Old 01-01-2013, 03:21 PM   #5
dinan19
Well then looks like its Defouler time! My buddy has the defoulers in his s2000 and it works so we'll see.
Old 01-01-2013, 09:47 PM   #6
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Maybe they're out of stock
Try this http://www.o2simulator.com/
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 01-01-2013, 10:47 PM   #7
dinan19
Ill look on there but ive been reading on m3 forum that using the spark plug defouler is more consistent in working.
Sent from my SGH-T959V using Bimmer App
Old 01-02-2013, 12:59 AM   #8
TerraPhantm
My Ride: M3 & ZHP
Something tells me defoulers wouldn't work that great on the MS45 330s since they have wide-band O2s... I could be wrong though.
Old 01-02-2013, 03:23 AM   #9
777eThOd*
My Ride: spins too much
You need patience and time for the spark plug defoulers to work right. They do work on the M54B25 and M54B30 tho.
2007 BMW 335i FBO 6MT - Current
2013 Nissan Nismo 370Z - Current
2004 Non-M Facelift Coupe - SOLD
2006 BMW M3 - SOLD
777eThOd* is offline   Reply With Quote
Old 01-02-2013, 04:17 AM   #10
dinan19
Time? Like do you mean at first the light will come on and then once the dme runs a cycle it will clear or what?
Old 01-02-2013, 04:21 AM   #11
777eThOd*
Time as in you might have to mess around with them for the light to clear. But I dunno, my guy does some work on the post o2 sensor connectors that tricks the DME into thinking I have cats and guarantee too pass emissions. Hmu like I said when you give up haha.
2006 BMW M3 - SOLD
Old 01-02-2013, 10:43 AM   #12
darksideracer69
My Ride: 01 325ci
Yea the o2 sims didn't work for me either. Idk why but whatever. Lc1 seems like the only option.
IMAG02051
Old 01-02-2013, 11:14 AM   #13
SoloII///M
My Ride: Many
Plug defoulers didn't work on my car. I tried a bunch of variations. No dice.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 01-02-2013, 03:37 PM   #14
dinan19
Wow that sucks cuz i was hoping to avoid having to swap out the headers for the stock manifolds just for emissions. I mean its a hell'ish job as it is just to put them on. I remember it took me 12 hours to put headers on my z4 and my buddy and i were cursing half the time and with bloody knockles.
Old 01-03-2013, 10:46 PM   #15
TrippinBimmer
My Ride: Just Fast!
o2 sim will work but will need a custom heater. I designed one at one point of time but to much work. I sold it with my old SS Headers...
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 01-04-2013, 06:01 AM   #16
SoloII///M
My Ride: Many
Just hang your O2 sensors in the drug bin and use only the heaters from them. Works great.
John V
Old 01-04-2013, 02:41 PM   #17
dinan19
What heaters?
Old 01-04-2013, 03:02 PM   #18
SoloII///M
My Ride: Many
The heaters built into the o2 sensors.
John V
Old 01-04-2013, 03:14 PM   #19
dinan19
I still dont get it im sorry. You say hang them from the drug bin and connect them to the heaters but you say they are built in?
Old 01-05-2013, 08:06 AM   #20
SoloII///M
My Ride: Many
You should probably do some searching here on what causes a CEL when you install catless headers - this all has been covered over and over.
Obviously your post-cat O2 sensors will throw a code without cats because your catalytic converter efficiency has failed. If you install O2 simulators in place of your O2 sensors (which still won't let you pass emissions in most states) you'll get a code for O2 sensor heater circuit failures because the sims don't have a heater circuit built in.
You can use the post-cat O2 sensors for this. They have heaters in them. You can plug them in just for purposes of having the heaters in the circuit. You can hang them in the drug bin or just screw them into the headers. Doesn't matter where you put them, they just need to be in the circuit.
John V
