E46 Xi Forum
Old 01-01-2013, 10:30 AM   #1
02vito
My Ride: 2002 325i
Bilstein HDs For 325xiT
Been getting some conflicting information about the correct part number for Bilstein HD rear shocks for a 09/2001 325xiT. Some sources suggest that the xi sedan and wagon [touring] use the same replacement rear shock.
Can anyone provide the number for the Bilstein HD shock known to be the correct one?
Thanks in advance.
02vito is offline   Reply With Quote
Old 01-01-2013, 01:34 PM   #2
Kubica
My Ride: 2003 325xi
Use the e36 m3 rear bilsteins with the front HDs if you are lowering at all (eibach springs). Otherwise the sedan rear HDs will work, unless someone on this forum disagrees. I don't have a wagon but I've seen bilsteins on a few wagons.
Old 01-01-2013, 02:30 PM   #3
Eurofreak13
My Ride: 325xiT, 318is, 318ic
If you can use the rears off of a e36 (M or Non M) can you use the fronts? Only reason I ask is because I've got a brand new set with no home.
Edit: nevermind I'm a idiot, the connection between the spindles are different
Eurofreak13 is offline   Reply With Quote
Old 01-01-2013, 03:27 PM   #4
325xittt
My Ride: 2003, 325 XIT
+1 to Kubica
I've been running Bilstein hd sedan shocks front and rear on my 325xit, not lowered. I like them
325xittt is offline   Reply With Quote
