#21 | |
#22 |
My Ride: Ex 325CI owner
#23 |
"BMW LL01(Longlife)" on the back label.
#24 | |
#25 |
#26 |
Any LL01 oil. If it doesn't meet LL01 then it needs to meet ACEA A3, B3 minimum. It's so very simple.
#27 |
Just an update.
LAdy at autozone price matched walmarts M1 0w40 for me. Walmart didn't have it. So picked up 8Q for 60$ Did the oil change today, was really easy. When I originally bought the car a few months ago, I was having all the leaks fixed and had non synth valvoline put in. idk what weight. Car feels much smoother after the change. So quick question. I put in 7Q and checked the dip stick, it was at the "low" mark. So I ran the engine, checked it, and let it cool then checked it again, was still low. I ended up putting 7.6Q in to get it to the "full" mark. Seems odd? I let the car drain for a while, and leveled it after it stopped dripping to get some more out. Last edited by GATORSHOES2; 01-05-2013 at 08:11 PM. |
#28 |
Where's goingnuts, he used to be all over these oil threads
![]() 2002 Carbon Black ///M3 - current 2002 Stahlgrau ///M3 - RIP 2001 325i - sold Instagram: @VONGEISS |
#29 |
Wears carbon fiber boxers
My Ride: 330Ci ZHP 6sp
Okay fine I'll do it, someone has to.
Ahem: You are using the wrong oil. Only BMW oil is to be used for oil changes. BMW LL-01 oil is only for topping up only, BMW does not recommend using them for a full oil change. You should only use Castrol for topping up, because BMW recommends Castrol. Mobil 1 0w40 has smaller molecules than Castrol and it leaks through gaskets. I've verified this because I had leaks when I topped up using Mobil 1. You should only use Castrol for topping off.* *These are things GoingNuts has actually said
E46Fanatic's resident mathemagician
![]() Last edited by Zell; 01-05-2013 at 10:02 PM. |
#30 |
His last post was in Nov 2011. He's either sold his E46 and moved on, or changed his user name.
The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed. |
#31 |
He's on bf.c these days... and spouting out more or less the same nonsense.
Though he does seem to have a stronger fixation on Hondas than before Last edited by TerraPhantm; 01-05-2013 at 10:05 PM. |
#32 | |
Buy a Honda.
#33 |
Well alrighty then.
#34 |
I buy the dealer oil. I run it about 8K miles and its not near as nasty as mobile one at 8K miles.
Dave |
#35 |
Sh1tty Advisor
My Ride: 323Ci 5 Speed Black
I just got myself 10L of Quaker State Ultimate Durability Full Synthetic 5w-30 motor oil for dirt cheap
![]() I am gonna use that for the next 7-8k miles and see if my engine blows up.
![]() Oops! My Water Pump Broke Again .................... Coolant in a Bottle Last edited by MercForHire; 01-06-2013 at 12:35 AM. |
#36 |
#37 |
I have used castrol gtx full synthetic 5w30 for as long as I have had the car and so did the previous owner (all the service records were kept in the glove box) and I am yet to have a malfunction oil related. I also own a shop and we use that for all cars requiring synthetic
Dedication
![]() _______________ Dedication |
#38 | |
Sh1tty Advisor
Not BMW LL-01 but who cares. Local mechanics have been putting the same spec Castrol Edge in all BMW cars. Just don't change them at 15k BMW dealer intervals
![]() Oops! My Water Pump Broke Again .................... Coolant in a Bottle Last edited by MercForHire; 01-06-2013 at 12:38 AM. |
#39 | |
#40 |
I use Shell Rotella T6 5w40 Synthetic. All of my friends use this oil as well in their BMW's. Shell Rotella is a great oil and can be picked up for half the price of other synthetic oil when purchased at menards or walmart
In addition to me, here is a bimmerforums review thread for T6 http://forums.bimmerforums.com/forum....php?t=1488700
"If you cant stand behind our Troops, feel free to stand in front of them." ![]() Last edited by redneckrice94; 01-06-2013 at 02:20 AM. |
