Old 01-02-2013, 02:59 AM   #1
Sam-I-Am328
My Ride: 2000 BMW 328i
Transmission swap???
I own a manual 2000 328i and Ive decided I want to swap for a coupe. I found this awesome 2001 330ci that I would of bought on the spot if not for one thing. Its an automatic . So I was hoping if someone could tell me how possible it is to swap the transmissions. Any advice or opinions would be much appreciated. THANKS
Sam-I-Am328 is offline   Reply With Quote
Old 01-02-2013, 03:08 AM   #2
zander271
My Ride: 6spd ZHP/5sp XI
Yes it can be done. Search the forums there is a ton of info on the subject. Also unless you can do the swap yourself, it would make more sense to just take more time and find a manual coupe.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 01-02-2013, 07:53 PM   #3
genius328i
My Ride: 328i
Just take of the torque converter off of the automatic engine and the wallah you have two manual trannies
Sent from my HTC Sensation 4G using Bimmer App
genius328i is offline   Reply With Quote
Old 01-03-2013, 05:34 PM   #4
Sam-I-Am328
Just to clarify.. theyre both 5hp19 right?
