Lights on while car is off - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-02-2013, 07:13 PM   #1
bmwjatt
My Ride: E46 325CI
This morning my keyless entry was not working (tried extra key still nothing), when I got closer I found out there are few light on the dashboard while the car is turned off. Battery, oil, DSC, cruise control, and automatic transmission/sequential manual gearbox and as well as the brake light on the back of my car are on.
The car drives fine and all the lights go away once I start the car. but come back when I turn it off..
So far, I have got the battery checked, its fine and pulled codes only code thats new is P0442 Emmission control system leak, that is my bad fuel cap most likely.
P0171 and P0174 been there for my low fuel pump fail..
Name:	bmw lights prob.jpg
ID:	484366   Click image for larger version
bmwjatt is offline   Reply With Quote
Old 01-02-2013, 07:16 PM   #2
Stinger9
My Ride: '04 330Ci
Never trust the average battery test.
How old is your battery?
Old 01-02-2013, 07:17 PM   #3
bmwjatt
My Ride: E46 325CI
About two years old.
Old 01-02-2013, 07:19 PM   #4
bmwjatt
My Ride: E46 325CI
I drove around for a while, if the battery was bad the battery light would go on...
Old 01-02-2013, 07:23 PM   #5
zhenkaaaM3
My Ride: Fst'r then your e46
I just noticed your temperature needle is on the red. Is that just not working?
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 01-02-2013, 07:25 PM   #6
bmwjatt
My Ride: E46 325CI
The car is not on. this while the car is turned off. Key is not in the egnition and I am getting all this.
Old 01-02-2013, 07:28 PM   #7
Stinger9
My Ride: '04 330Ci
Incorrect. The idiot light does not detect a weak or erratic battery.
Old 01-02-2013, 07:29 PM   #8
bmwjatt
My Ride: E46 325CI
I see, I did get it check by Pepboys, they did load test and everything.
Old 01-02-2013, 07:30 PM   #9
Stinger9
My Ride: '04 330Ci
Yeah, then the temperature gauge is whacked too.
Should never rest in this position.
This could be an expensive problem to troubleshoot. Now I'm starting to think you may have a problem with the gauge cluster.
I'd still like to see a different battery subbed in there for comparison. Too bad you don't have a friend.
Old 01-02-2013, 07:31 PM   #10
Stinger9
My Ride: '04 330Ci
I understand, just I've read about so many getting a load test and eventually it was the battery after it tested OK.
Old 01-02-2013, 07:32 PM   #11
bmwjatt
My Ride: E46 325CI
That is what I think as well, but not sure so just bouncing ideas to make sure. I also heard about the short in the tail lights that causes cluster issues.
Old 01-02-2013, 07:50 PM   #12
Stinger9
My Ride: '04 330Ci
Completely logically then to repair the short in the tail lights to see if it's a fix.
As that is by far the easiest thing to repair first as long as we're guessing.
Old 01-03-2013, 12:45 PM   #13
bmwjatt
My Ride: E46 325CI
So I dissconnected the positive cable all nite. this morning same thing, so I figured its the battery or the problem would have gone away during nite. went to walmart popped a new battery in the parking lot. Same things even ran the car for few minutes with new battery.
When I got home I started pulling the fuses to see if it will go away. when I pulled the number 43 fuse for the cluster panel the lights went away along with the brake lights. Fuse 43 and 34 have black stuff in them but does not look blown.
please advice?
Old 01-03-2013, 12:53 PM   #14
zhenkaaaM3
Fuse is not blown unless the line is broken inside the fuse. Its very noticeable.
Eugene
Old 01-03-2013, 12:55 PM   #15
bmwjatt
My Ride: E46 325CI
I just uploaded the pics of fuses, yes I am aware of that.
Old 01-03-2013, 01:17 PM   #16
taibinhvuong
My Ride: E46 99' 328i
Fuse #43(5A) is on-board diagnose II, if the fuse has black stuff or burnt mark on it, it means the circuit has excessive current or the fuse just deteriorates to the point that limited the current to the on board diagnose II, thus caused the malfunction that you have, just replace the fuse and eliminate the cause is the easiest thing to do.
taibinhvuong is offline   Reply With Quote
Old 01-03-2013, 04:00 PM   #17
Stinger9
My Ride: '04 330Ci
wish it were so easy
I don't think so. That he gets a difference with the fuse pulled indicates that the fuse is not blown.
And replacing a blown fuse, if that were the case, will 95% solve nothing. Fuse is symptomatic of a problem, not the problem typically.
Have to find out what blew or fatigued the fuse for the cure. Sounds like OP has a problem with one of the devices that the fuse feeds.
Old 01-03-2013, 05:02 PM   #18
dknightd
My Ride: 2002 330 cic
epidemic? http://forum.e46fanatics.com/showthread.php?t=963747
dknightd is offline   Reply With Quote
Old 01-03-2013, 05:08 PM   #19
bmwjatt
My Ride: E46 325CI
I just popped new fuses and started the car, the problem went away. but still do you think this could be the end of it....
For now I am happy...
Old 01-03-2013, 05:13 PM   #20
bmwjatt
My Ride: E46 325CI
what is OP?
