Sponsored by BimmerWorld
Old 12-19-2012, 08:12 PM   #1
hueyhy
My Ride: E46 330i
Could alignment work bring in clunking noise?
Done my control arm and tie rod end replacement yesterday.
after that I immediately drove to a alignment shop and done the alignment.
while I was driving to there, there's no clunking IIRC
Today when I drove the car I found there's clunking in the front when have small bumps on the road.
my question is, is it because some loose nuts/bolts (maybe because when I tighten them, the car is not loaded)
or it might be caused by the guy doing the alignment?
(I have a camber plate, and he adjust it by loosen the three bolts holding the strut mount to the chasis, and smack the top )
Where could I check?
another thing I could think of is, when I put on the control arm, I tightened the bushing bracket first, and then the ball joints. I don't know if this is a wrong sequence and don't know if this could cause loose nuts when the car is loaded.
hueyhy is offline   Reply With Quote
Old 12-20-2012, 09:54 AM   #2
heechkass
My Ride: 323i Touring, 2000
Check the lock nut on the tie rod. Maybe they didn't tighten it.
heechkass is offline   Reply With Quote
Old 12-20-2012, 12:23 PM   #3
djantlive
My Ride: E46 M3
a loose nut would make the car wonder and loose alignment. not necessarily a clunking noise.
djantlive is offline   Reply With Quote
Old 12-20-2012, 02:25 PM   #4
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Could be a loose nut or something. You should go back to the alignment shop and let the person who performed the alignment know that you are now experiencing some clunking/noises that weren't present before the alignment, so you want to double check to make sure everything that was adjusted is to the proper torque specs.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 12-20-2012, 04:54 PM   #5
My Ride: 2016 Lexus
Why do you have camber plates?
Old 12-22-2012, 12:29 AM   #6
DenverSooner
My Ride: 2014 328d xDrive
Sway bar end links.
DenverSooner is offline   Reply With Quote
Old 12-22-2012, 01:20 AM   #7
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Originally Posted by DenverSooner View Post
Sway bar end links.
Bam. 9/10 this is it. For some reason these often need to be tightened twice. Once. And then once again after like 50-100 miles.
Hope this helps.
Old 01-03-2013, 12:29 AM   #8
bmw4130
My Ride: E46, BNR32 & BCNR33.
Hope this helps.
Hmmm is that a common issue? I just changed the front sway bar links right before thanksgiving. Tonight I'm hearing knocking noise in the front left. I was thinking swaybar links also. I was shaking my head saying I just changed these???
bmw4130 is offline   Reply With Quote
Old 01-05-2013, 12:11 PM   #9
Whinojosa
My Ride: 2004 BMW 325i
+1 on the links - tighten them with suspension loaded on ramps. I've experienced that issue - it's LOUD and vibrates tremendously.
Whinojosa is offline   Reply With Quote
