E46 Xi Forum
Old 01-02-2013, 11:26 PM   #1
Smurphymurphy89
My Ride: 2005 325xi
Cold start problem
I have the same problem starting my BMW 05 325xi it starts right up while warm but in the cold it does not start with the same problem your describing it cranking but not turning over the battery was just changed and it's not the starter or the alternator I checked the fuel pressure when warm and fuel pressure when cold and the results were the pressure was alot less in cold weather as to in warm weather has anyone else had this problem if so how can I fix it please
Smurphymurphy89 is offline   Reply With Quote
Old 01-03-2013, 11:58 AM   #2
SamDoe1
My Ride: 4cyl of fury
Replace fuel filter and fuel pump.
Old 01-03-2013, 04:42 PM   #3
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
When was the last time the Fuel FIlter (which also has the Fuel Pressure Regulator as part of it)replaced? Also worth checking the Fuel Pump in the gas tank, depending on the mileage, it could be weak/starting to go.
tomoyer is offline   Reply With Quote
