Sponsored by BimmerWorld
Old 01-09-2013, 09:19 AM   #21
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Can you do a test for us? Can you rebuild your caliper first to see if it is your caliper differences? If that does not fix the twitch, then you can replace your lcab.
It would be a good way to find out what really causes the twitch.
BMWCaptain is offline   Reply With Quote
Old 01-09-2013, 03:02 PM   #22
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
I would say either front Control are bushings (FCABs) or the front passenger rotor is warped (uneven wear) Good luck dude
Originally Posted by MercForHire View Post
Spends $2000 on car DVD + stereo -> Running 25000 mile oil changes and 87 gas with blown shocks
aahmed2016 is offline   Reply With Quote
Old 01-09-2013, 10:44 PM   #23
JokerElite
My Ride: 95 M3, 04 M3, 09 328
I think the twitching was caused by the rebuilt brake caliper. The FCABs aren't likely to cause the sudden twitch and thump noise, especially when stopped. And the pulling is probably because of the rebuilt brake caliper as well.
I guess the grease I used for the piston when rebuilding the caliper wasn't good and messed with the how it operates. That's what I believe is causing the piston to suddenly move instead of pressing and retracting smoothly.
It seems it's a coincidence that the FCABs are out, they might have been out for a while now but this problem led me to checking them. The way they look though is strange, looks like the rubber on them has melted.
I'm still working on everything and I'll try to keep updating.
1995 BMW M3 - Avus Blue | 2004 BMW M3 - Jet Black | 2009 328xi - Alpine White
JokerElite is offline   Reply With Quote
Old 01-13-2013, 11:46 PM   #24
JokerElite
Replaced and FCABs and rebuilt both calipers. Although one of the FCABs was out, it didn't cause any noticeable problems. But it's still good they were both replaced anyway as maintenance. The caliper was most likely causing the twitch and the pulling. Or the piston in particular.
It was probably doing this because of the lubricant I used when originally rebuilding one of the calipers. Could have caused the piston to not function smoothly. Or upon disassembling that caliper, when I removed the gasket/o-ring and compared it to a new one it was bigger in diameter. It wasn't that size when previously rebuilding it. Not sure how the size changed but that could have been causing an interference to the piston's operation.
Thanks for the help everyone!
Old 01-14-2013, 12:01 AM   #25
BMWCaptain
Originally Posted by RayPooley View Post
No its not. Check out his passenger side FCAB in the vid above.
I guess it was the caliper and not the fcab causing his twitch.
