Old 01-03-2013, 04:18 PM   #1
SpoonerDee
My Ride: 2005 E46
Never seen or heard of this before. Electrical problem?
I'm sitting in my office when my wife comes back from an appointment and tells me it looks like my brake lights are on but she couldn't really tell because the light from the sun was on them. So I go outside and look and sure enough all 3 brake lights are light up.
I walk to my driver door and notice that almost all the warning lights on my cluster are on, dsc light, brake light, light out warnings for the brake lights, check engine light etc (don't remember if all of them but it seemed like it as I was freaking out).
So I push the door open button on my key and nothing. Push it again, nothing. I manually unlock the door get in and see all these lights still on. So I put the key in, turn it and the car barely cranks to life.
A moment later the DSC light goes off as do the other lights. The light that says brake stays on for a moment then goes off as does the brake light out warning and she tells me the lights then went off.
I have not driven my car since yesterday and have walked passed it several times today and they were never on. She was gone for about 2 hours and when she left they were not on so this happened just recently.
Anyone ever see anything like this before? To me it sounds like a short or something, but to cause them to all go on like that seems really odd.
SpoonerDee is offline   Reply With Quote
Old 01-03-2013, 04:23 PM   #2
SpoonerDee
My Ride: 2005 E46
Also, every time I turn the car off now, the lights come back on.
Old 01-03-2013, 04:41 PM   #3
BimmersGarage
My Ride: E46 330i
battery gremlins.
When our batteries start to fail (usually after 5 years) these cluster warning lights start to act up just like you described.
Have the battery tested. But, be ready to get a new unit.
BimmersGarage is offline   Reply With Quote
Old 01-03-2013, 04:42 PM   #4
trj
My Ride: 325Ci
Get your battery tested. Most probably the battery is weak.
Weak batteries create havoc in our cars.
Old 01-03-2013, 04:43 PM   #5
SpoonerDee
My Ride: 2005 E46
Really? That is absolutely insane lol thanks for the timely response.
Old 01-03-2013, 05:15 PM   #6
Muzzychris
My Ride: 2001 325 convertible
I had a similar problem, if a new battery doesn't solve it it could be a k-bus issue, first I would try leaving the battery disconnected for 2 hours and reconnect and see what happens.
Muzzychris is offline   Reply With Quote
Old 01-03-2013, 06:00 PM   #7
dknightd
My Ride: 2002 330 cic
this guy seems to have the same problem http://forum.e46fanatics.com/showthread.php?t=963586
dknightd is offline   Reply With Quote
Old 01-03-2013, 06:26 PM   #8
bmwjatt
My Ride: E46 325CI
I put new fuse in 34 and 43. Then started the car. Its gone away.
good luck.
bmwjatt is offline   Reply With Quote
Old 01-03-2013, 06:37 PM   #9
jfoj
My Ride: 330CiC, M5, X5
Could be a battery running low, could be a bad battery, could be a bad FSU (search and you will find PLENTY on the FSU).
See 3rd link below in signature to display battery/charging Voltage on the OBC display.
Old 01-04-2013, 08:13 AM   #10
SpoonerDee
My Ride: 2005 E46
good luck.
Yeah was just reading your thread. Will check my fuses later today and see if mine look like yours.
Old 01-04-2013, 08:43 AM   #11
SpoonerDee
My Ride: 2005 E46
Update:
I left the battery disconnected over night. Went and checked those same fuses and they are fine. So I hooked the battery back up, no lights, no warning lights and the car responded to my key again. Turned the key and she fired up again with no issue.
Should I go through and check all my fuses or assume it still might be the battery?
