Old 01-03-2013, 05:00 PM   #1
darksideracer69
My Ride: 01 325ci
Need some help guys. E46 with boost
So I'm trying to help a friend out with his 325 that has an active kit on it. Stage 2. You turn the car on and it doesn't want to stay on. Sometimes it'll stay on but as soon as you push the gas it'll die. The maf, idle control valve has already been checked. I replaced the vanos seals today, along with some exhaust gaskets. Nothing changed. I'm leaning towards a boost leak somewhere, or the throttle body. I have checked for errors using inpa and there are none.
And ideas or help as to what may be causing this would be appreciated.
Thanks.
Sent from my PC36100 using Bimmer App
IMAG02051
Old 01-03-2013, 05:14 PM   #2
Hornung418
My Ride: '04 MB ZHP
Active? Probably the tune.
Sent from my SCH-I535 using Bimmer App
Hornung418 is offline   Reply With Quote
Old 01-03-2013, 05:30 PM   #3
darksideracer69
My Ride: 01 325ci
You think? I thought is would be pretty random for the tune to just mess up.
IMAG02051
Old 01-03-2013, 07:23 PM   #4
Hornung418
My Ride: '04 MB ZHP
Fuel filter?
Old 01-03-2013, 07:28 PM   #5
jamex
My Ride: 2005 325Ci
Try asking over in the Forced Induction sub-forum. If anyone can sort you out, they can
jamex is offline   Reply With Quote
Old 01-03-2013, 07:39 PM   #6
FastHackem
My Ride: E60 M5
+1 on an air leak
Sent from my Nexus S 4G using Bimmer App
The Mind Is A Terrible Thing.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
FastHackem is offline   Reply With Quote
Old 01-03-2013, 08:07 PM   #7
darksideracer69
My Ride: 01 325ci
It runs pretty rich, so I don't think it would be the tune or fuel related.
IMAG02051
Old 01-03-2013, 08:53 PM   #8
darksideracer69
My Ride: 01 325ci
Can a mod love this?
IMAG02051
Old 01-03-2013, 10:45 PM   #9
TrippinBimmer
My Ride: Just Fast!
That is what I thought...
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 01-05-2013, 11:09 AM   #10
stuntin325
My Ride: 2001 325
You should check for an air leak,clean throttle body, then from their check if map sensor is working right
stuntin325 is offline   Reply With Quote
