Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > UK
UK
Have you seen another BMW while driving around in your area? Find other members from your area in the E46Fanatics Garage HERE
Old 01-04-2013, 10:42 AM   #1
Eleme3804
My Ride: 325ci
No start
My 325ci (yr 2000) fails to start" battery is fine,got plenty of fuel, fuel pump is priming, the car turns over but won't fire??? ( although it is trying every so often ) any known quick fixes or possibilities
All suggestions welcome
Eleme3804 is offline   Reply With Quote
Old 08-19-2013, 12:00 PM   #2
328iM52
My Ride: 2000 328i tiptronic
I recently had a similar issue - my problem was the crank sensor, infact thats a lie.... my PROBLEMS turned out to be crank sensor fail, cam sensor fail and now it looks like fuel pump fail!! all in 4 days.
The issue you have is that it could be fuel delivery related also which opens up another can of worms. I am lucky i have managed to diagnose the issue quite quickly although saying that, I won't know if shes cured until tomorrow......
Whats the milage?? Mines a '00 328i tiptronic, still just under 140k
328iM52 is offline   Reply With Quote
