E46 Convertible
Old 01-04-2013, 01:59 PM   #1
crow2112
My Ride: 330 m sport 2001
electrical fault
hi, ive just registered so new to it all i have a problem withmy car, i drive it today and parked it up and when i got back into the car and turned the key it wouldnt start, as i didnt even turn over and all ignition lifhts stay on. it has also affected my sound system, everytime i turn the key it jus click then everything goes intermittant...
...any ideas?
many thanks
crow2112 is offline   Reply With Quote
Old 01-05-2013, 08:16 AM   #2
E46DrEaMeR
My Ride: 2004 330ci
1st thing get battery checked 2nd get alternator checked then go from there hth
Its a ragtop thing! you wouldn't understand
E46DrEaMeR is offline   Reply With Quote
Old 01-05-2013, 12:19 PM   #3
pauljcl
My Ride: 2005 330cic
+1 -
pauljcl is offline   Reply With Quote
Old 01-07-2013, 04:42 PM   #4
hagsdg7
My Ride: 2004 325ci
Sounds like battery. Pull it, get it tested to see what it's putting out. Also see how old it is- if it's just old and gone, easy fix. If it's a newer battery and it's toast, look into alternator, shorts, terminals, etc. lots of "it won't start" threads around, especially in the vert forum.
hagsdg7 is offline   Reply With Quote
Old 01-07-2013, 09:06 PM   #5
Max'd out
My Ride: 04 330cic
Check for battery condition with on-board computer without having to remove battery. Search forum for "hidden codes" or "OBC".
Max'd out is offline   Reply With Quote
