E46 Xi Forum
Old 01-04-2013, 02:02 PM   #1
akhoundog
My Ride: 01 325xi wagon 5spee
"hot" burning smell
i recently bought a well kept 01 325xi wagon with a manual, i bought it knowing the valve cover was seeping and since replaced it however there is still a "hot" burning smell after traveling on the highway. I don't think it's engine oil cause it has a different smell and doesn't come in the cab while driving. the odor seems to be stronger under the car, i thought it could be the clutch so i tried to get the clutch to slip under WOT on the highway at around 3k-4k but didn't notice the tach jump. the clutch seems to bite strong. any ideas?
akhoundog is offline   Reply With Quote
Old 01-04-2013, 02:04 PM   #2
diM3tri
My Ride: 330ci + stg2 Scoobie
It is just left over oil that's still on the exhaust manifold. Drive around for a few days and eventually it will go away
Current Cars:
'99 Big Turbo B5 A4 (the red one) ^^^
'13 GLI
'91 Ford F150 v8 5spd
Previous Cars:
'05 stg 2 scoobie wagon
'82 VW rabbit vert
'01 330ci
'84 633csi
diM3tri is offline   Reply With Quote
Old 01-04-2013, 02:09 PM   #3
akhoundog
I'v got about 150 miles on it since I did the valve cover gasket, mostly city driving. how long could i expect oil to burn off?
Old 01-04-2013, 02:11 PM   #4
diM3tri
How messed up was the VCG? The oil leaks out onto the exhaust manifold which then burns thy dripping oil.. If there was a lot of oil on the exhaust manifold from before the VCG was done, it will stay there until it gets burned off. Did you do the VCG yourself or did you get a shop to do it for you?
Current Cars:
'13 GLI
Previous Cars:
'82 VW rabbit vert
'01 330ci
'84 633csi
Old 01-04-2013, 02:16 PM   #5
akhoundog
i did the VCG myself, there wasn't a great deal of oil leakage but the small aluminum heat shield right above the manifold was stained with cooked oil and the center gasket was torn around center bolt holes. the old VCG was mildly stiff but still intact. i properly cleaned up the head and used red RTV around the half moons and around the bolt holes.
Old 01-04-2013, 08:06 PM   #6
akhoundog
could this be the oil separator?
Old 01-04-2013, 09:04 PM   #7
Kubica
My Ride: 2003 325xi
Replace VCG.
Old 01-04-2013, 09:21 PM   #8
akhoundog
Read above
Old 01-04-2013, 09:48 PM   #9
denvermgb
My Ride: 2002 325XIT
It could be the gasket for the oil filter cartridge holder. It is not as obvious as the VCG as it is tucked down against the engine. I had to replace mine at about 100k miles. Good luck!
denvermgb is offline   Reply With Quote
Old 01-05-2013, 12:33 AM   #10
akhoundog
ill check that out! thanks. this sunday i plan on doing plugs, oil filter housing gasket (weeping a lil), water pump, belt and coolant tank. i'll get a better view then.
Old 01-05-2013, 01:27 AM   #11
Dreamliner330
My Ride: 330xi
If your doing the OFHG you may as well do the CCV & connecting tubes. Super easy with all that crap off.
I just replaced my Valve Cover (came with new gasket), OFHG and CCV+Connecting Tubes (Cold weather version). I cleaned the DISA & Throttle Body while everything was apart.
Also if your going to do the CCV, pull your dipstick tube and make sure the line is clear from the CCV drain tube.
Took about 8 hours for all of that. (I work slowly and carefully).
Dreamliner330 is online now   Reply With Quote
Old 01-05-2013, 09:49 AM   #12
Kubica
My Ride: 2003 325xi
^why did you buy a whole valve cover?
Old 01-05-2013, 10:37 AM   #13
Kubica
My Ride: 2003 325xi
I've never heard of putting rtv around the bolt holes. I think your vcg is still leaking. Did you use an OE gasket set? Victor Rainz brand is known to leak.
Old 01-05-2013, 10:37 AM   #14
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
sometimes they crack, especially when someone replaces the vcg without replacing the rubber grommets and proceed to torque the crap out of the bolts.
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 01-05-2013, 11:55 AM   #15
akhoundog
I will get the CCV and hoses and do it at the same time, that makes total sense. This sunday I shall just do plugs and install a pan heater.
Old 01-05-2013, 11:58 AM   #16
akhoundog
I used a victor rainz VCG. When i do the plugs on sunday ill have the engine cover off and have a little better view.
Old 01-05-2013, 12:00 PM   #17
akhoundog
Is there a seal on the dipstick tube i should replace?
Old 01-05-2013, 12:23 PM   #18
///MPR77
My Ride: 02 ///M3 Tri-Ped
Refer to this thread:
http://forum.e46fanatics.com/showthr...mbers thread**
Sent from my SCH-R530M using Bimmer App
oil, smell
