Sponsored by BimmerWorld
Old 01-04-2013, 04:52 PM   #1
pone
My Ride: 325xit
fcab lollypop tool options
the only tool i've found for removal and installation of the control arm bushings into/out of the lollypop brackets is the mis tool version. i nearly hit "pay" before double checking the applications list and it looks like it only works on m-series e46 models with 60mm diameter.
is this the only diy tool out there?
(i've already purchased rubber oem replacement bushings as i'm not interested in the urethane options.)
thanks in advance.
pone is offline   Reply With Quote
Old 01-04-2013, 07:03 PM   #2
My Ride: Lexus
3 jaw puller rented from autozone.
Old 01-04-2013, 07:28 PM   #3
pone
My Ride: 325xit
are you referring to removing the bushing and bracket from the control arm?
i'm not sure how a 3-jaw puller could install the bushing into the lollypop....
Old 01-05-2013, 08:09 AM   #4
SoloII///M
My Ride: Many
I always install the bushings onto the front control arms using a little dish soap and my hands. Never had a problem
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 01-05-2013, 10:48 AM   #5
pone
My Ride: 325xit
i'm not talking about getting the bushing onto the control arm. i'm referring to removing and installing the bushings in their holders/brackets.
Old 01-05-2013, 10:57 AM   #6
pone
My Ride: 325xit
getting one of these bushings...
... inside of this bracket
i guess no one sells a tool for this that fits a non-m e46, short of a shop press. mis tools sells this
but for other applications. oh well, thanks for looking.
Old 01-05-2013, 11:53 AM   #7
Whinojosa
My Ride: 2004 BMW 325i
I know what youre talking about. I installed Rogue CAB's into the original "lollipop" bracket. Meaning I pressed out the old bushing and housing out of the lollipop bracket. Then installed the new bushing and housing into that lollipop bracket.
I used a 6-Ton hydraulic press from harbor freight (scary quality stuff, this I know). I pressed out the old housing using a metal plate to go as far as I could. Then lined up the new housing perfectly with the old one inside of the lollipop bracket and pressed old out while pressing new in. I did not use a special tool although I considered fabricating a circular plate to press out the old ones. It probably would have been much easier to use a specialized tool - if you can find a 66mm one. However, it possible without.
Whinojosa is offline   Reply With Quote
Old 01-05-2013, 11:57 AM   #8
M325er22
My Ride: 2001 325i
You could use a big C clamp from oriellys, autozone, etc to push out the old and install the new one. I rented it for 120 and when I returned it, I was refunded.
Two people would be best because the clamp is heavy and awkward to control with 2 hands.
HTH
Sent from my LG-P509 using Bimmer App
M325er22 is offline   Reply With Quote
Old 01-05-2013, 12:10 PM   #9
pone
My Ride: 325xit
that's what i'm talkin about.
it looks to me like there's bushing sticking out each side of the bracket, the bracket depth is less than the bushing length. using the big c-clamp, is there an issue with the back-stop of the clamp blocking pushing the bushing in so it sticks out on both sides?
Old 01-05-2013, 03:10 PM   #10
M325er22
My Ride: 2001 325i
Well I just pushed one out completely the installed the new one. Use a small ring from the pack to push it out and a ring should be about the s ame size of tge bracket.
Old 01-05-2013, 04:54 PM   #11
SoloII///M
My Ride: Many
Oh.
To do that, I use my shop press.
John V
Old 01-05-2013, 06:22 PM   #12
pone
My Ride: 325xit
was the tool something like this?
Old 01-05-2013, 11:57 PM   #13
M325er22
My Ride: 2001 325i
Yes! Thats it!
Old 01-06-2013, 09:14 AM   #14
pone
My Ride: 325xit
cool. thanks for the tip.
