Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 12-17-2012, 12:24 PM   #1
stamarev
My Ride: @
Weird sound on right turn
Hi,
I get very wierd sound which I can't identify. On older BMWs, when you open a trunk, the trunk's struts make a sound similar to "whining".
Now, when I am driving for a while, and then go to a parking lot, and finally go to a parking spot. If that spot is to the right, somewhere in the middle of a turn, I hear that "whine". Sometimes I hear it when I return the steering back to neutral position, car already standing still.
It does not hapen all the times. And it is not loud, but noticeable.
Belts and pulleys are relatively new.
Anybody has any ideas?
Thanks!
stamarev is offline   Reply With Quote
Old 12-17-2012, 12:32 PM   #2
j_block
My Ride: 2003 325i
Wheel bearing?
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 12-17-2012, 01:47 PM   #3
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
Originally Posted by stamarev View Post
Hi,
Thanks!
What year make and model car are you having this issue with?
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 12-17-2012, 01:51 PM   #4
stamarev
My Ride: @
It is 2002 325i 5-sp, around 140000mi
Old 01-07-2013, 07:35 AM   #5
Brandon330ci
My Ride: 2003 330Ci
Bump. I'm having this exact issue but when I go left, and when returning the wheel straight after turning left. It only happens at very low speed turns, and it sounds like it is creaking while I turn
Brandon330ci is offline   Reply With Quote
