Sponsored by BimmerWorld
Old 01-05-2013, 11:46 AM   #1
redneckrice94
My Ride: 2000 323i
Race Suspension?
I am planning on upgrading my suspension but am not sure whether to choose coilovers or shocks/springs. I will be tracking this car about 3-5 times every summer.
Currently my plan is koni yellow shocks with h&r race springs.
What do the expirienced guys think?
Sent from my SPH-D710 using Bimmer App
"If you cant stand behind our Troops, feel free to stand in front of them."
redneckrice94 is offline   Reply With Quote
Old 01-05-2013, 12:05 PM   #2
LeviMatt
My Ride: 328i
I say get coilovers with adjustable dampening that way you can change how stiff or soft the ride will be according to the track
LeviMatt is offline   Reply With Quote
Old 01-05-2013, 12:10 PM   #3
redneckrice94
My Ride: 2000 323i
Koni Yellows are a shock with adjustable dampening capabilities.
Old 01-05-2013, 12:18 PM   #4
LeviMatt
My Ride: 328i
Ohh my bad haha I just got my colors mixed up. They should be great if you not worried about ride height adjustability.
Old 01-05-2013, 12:20 PM   #5
redneckrice94
My Ride: 2000 323i
I just dont understand if height adjustability is really necessary. I thought height adjustability was more for looks?
Old 01-05-2013, 12:40 PM   #6
LeviMatt
My Ride: 328i
Its mostly used for looks on our car but you have to keep in mind that the lower your center of gravity is, the better your car will handle.
Old 01-05-2013, 12:46 PM   #7
redneckrice94
My Ride: 2000 323i
I do understand that, and the race springs do lower quite a bit while also giving a better spring rate. I just am not sure what most guys use on the track.
Old 01-05-2013, 12:59 PM   #8
Weapon ///M
My Ride: E46
I improved 4 seconds on my lap time changing from Koni Yellow/H&R Race to this system: http://gf-performance.com/index.php?...oducts_id=1631
Custom spring rates and valving are free. It comes with shortened sway bar linkage, full ride height adjust ability, rear shock mounts, CAMBER PLATES, linear springs and 30 levels of dampening adjustment.
Shoot ryan@gf-performance.com an email and ask if they are still offering discount codes on the system, he helped me out a lot when ordering mine.
Weapon ///M is offline   Reply With Quote
Old 01-05-2013, 03:20 PM   #9
BMWespresso
My Ride: 2005 325CI
with coilovers you'll be able to do corner balancing, that would be the only need for hight adjustment
with coilovers the front springs would be linear, better feel and handling.
BMWespresso is offline   Reply With Quote
Old 01-10-2013, 12:43 PM   #10
Sales@TSS
Sales@TSS's Avatar
My Ride: 1995 BMW E36 325i
Coilovers will net the best results on the track. Ideally the KW Club Sport kit would be the kit. Here is a some quick highlights of the Club Sport
*Height adjustable coilovers
*Performance setup for the racetrack
*Dampers in compression & rebound forces independently adjustable
*Use of high performance linear race springs
*In stainless steel technology inox-line
*Additional available with racing top mounts
The kit will set you back a decent chunk of change but it is the kit for a lot of track use. I have a couple friends who track their cars with KW V3s with great results. The kit is a bit cheaper than the Club Sports. Couple highlights on KW V3s
*Damping technology with individually adjustable rebound- and compression technology inox-line* stainless steel technology
*Individually height adjustable
*Adjustment parameters approved by the German Technical Control Board (TÜV)
*High-quality components for long durability
*Infinitely variable rebound damping adjustment
*14-way adjustable compression damping
*Unique, individually working damping force adjustment
*Comprehensive documentation for easy use
Let me know if I can answer any questions or provide you a price.
Sales @ The Suspension Source
www.thesuspensionsource.com
5654 E. Westover #112
Fresno, CA 93727
1-888-230-1288
Sales@TSS is offline   Reply With Quote
Old 01-27-2013, 10:10 PM   #11
BigDRick323
My Ride: 2000 323i
IInterested in more info as well on this...
Old 01-27-2013, 10:54 PM   #12
JaaPee
My Ride: ///M
Take a look at trm coilovers.
JaaPee is offline   Reply With Quote
Old 01-27-2013, 11:06 PM   #13
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
I vote mid, to high end coil overs. I have the same setup you're considering and it's a great setup for a daily driver that may see some track. I also have a car with coilovers they are fairly aggressive. I do not recommend aggressive coilovers for daily use because they're seriously harsh. But they handle so good it's not even funny. Loads better than my h&r and konis.
It really depends on what you're gonna use it for.
The best handling will be coilovers but they will not be happy on the street. At least not racing coil overs.
