Old 01-05-2013, 06:12 PM   #1
erich330ci
My Ride: 2004 330ci
Spray Paint
First, I'm a new member and this is a GREAT forum! Soooo much useful information!
Now my question: I'm looking to paint my trunk lip spoiler, but don't want to pay a shop +/- $100 to do it. There are a few online retailers who sell spray cans. I need titanium silver metallic for a 2004 330ci. I took a look, but didn't see any particularly recent threads on this subject. Any recommendations would be greatly appreciated. Thanks.
Eric H.
erich330ci is offline   Reply With Quote
Old 01-05-2013, 06:20 PM   #2
328iguy24
My Ride: e46 328i
http://www.gocolours.com/
Provide them with your car's Paint code and they're make you the OEM paint in spray cans.. I think its around $40 for like 4 or 5 cans.
<img src=http://i105.photobucket.com/albums/m230/josh19_01/IMAG0640-1-1_zpsc9e95ef1.jpg border=0 alt= />
328iguy24 is offline   Reply With Quote
Old 01-05-2013, 06:22 PM   #3
ixtoxi
My Ride: 02 330xi, 88 325iX
I asked my local BMW dealer who did their body shop and paint work, and they hooked me up with a local shop and paint provider. They took my paint code and matched it perfectly. Mine is Alpine White. There are many shades of "white", but they got it just right. Can't see a difference in the new paint and my 10-year-old paint. I'm sure you can find a similar shop in Baltimore.
ixtoxi is offline   Reply With Quote
Old 01-05-2013, 06:34 PM   #4
choxor
My Ride: JDM
If you have never painted before doing it by rattle can is most likely going to come out looking terrible. And if it does it'll cost you more in the end than if you had it painted by a shop to begin with.
If you do want to do it yourself there are plenty of youtube videos on painting parts with a can. It is possible to do it, but the key is prep. You're going to need primer and clear as well.
Old 01-05-2013, 07:27 PM   #5
2003silver330i
My Ride: 03 BMW 330i
Practice on something with the rattle can first before applying it to the actual piece. It's not hard to do at all. Just takes a little patience and practice to learn how the spray lays down depending on the sweep speed and distance. Practice makes perfect.
2003silver330i is offline   Reply With Quote
Old 01-05-2013, 08:45 PM   #6
trj
My Ride: 325Ci
OP, I know you are looking for a paint advice. Painting without experience and required tools is a big no no.
Why not just buy a painted one from ebay.
$30 and it comes painted with double sided tape and what not.
I have it on my coupe for more than a year and it has not changed color or lost any shape.
Get something like this:
http://www.ebay.com/itm/Painted-BMW-...85aaba&vxp=mtr
I dont have the link to the one I bought but there is a thread about this kind of spoiler. I guess it is called "post pictures of ebay spoiler" or something similar.
Old 01-05-2013, 09:10 PM   #7
2003silver330i
I disagree with this statement.
Old 01-05-2013, 09:30 PM   #8
zhenkaaaM3
My Ride: Fst'r then your e46
Sorry to thread jack but where do i click to buy?
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 01-05-2013, 09:43 PM   #9
wildirish317
My Ride: 2004 325Ci vert
Keep this in mind, and the fact that it's only a spoiler, and go for it. It's not like you're going to ruin the car. You'll learn a lot in the process.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 01-05-2013, 10:25 PM   #10
trj
My Ride: 325Ci
Sorry but, if I am going to paint something I better have all the required equipment. A covered enclosed area if not a paint booth. And a good air brush spray or whatever it's called.
OP you can try it in the open if over spray everywhere doesn't bother you. Else it's just going to be too much work and if you ruin it, you have do the whole job again.
Old 01-05-2013, 11:15 PM   #11
2003silver330i
see wildirish post above yours
Old 01-06-2013, 01:27 AM   #12
trj
My Ride: 325Ci
I am not against painting by self. But why spend time and money when you can have the factory paint matched spoiler for less than the paint cost with risk of ruining it or do it again if you ruin it.
Old 01-06-2013, 01:59 AM   #13
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
It's one thing to pick up a can of paint, even the factory mixed color, and paint the part expecting a job that will look acceptably similar to the factory job. It's another thing to actually make that happen.
Besides paint, if you wan't to do this the way a professional painter would do this, you will requre these materials.
  1. 2 sheets of each grade wet/dry sand paper 100g,220g,320g,400g,600g,800g,1000g,1500g,2000g.
  2. A 1x3x5 closed cell foam block that you can form into a sandng block to be used with the sandpabper.
  3. A spray bottle for water.
  4. A solvent bottle for squirting laquer thinner to clean parts.
  5. A flexible surface prep rattle can. A sandable hi-build primer.
  6. An organic mask, to keep the fumes away.
  7. A buffer, 3 type of buffing pads, and at least to types of polish.
What they didn't tell you at the shop is that BMW factory painjobs have a clear coat over the top of them so you're going to need that too. The clear will need to be an air dissolving catalyst to work from a rattle can. Add to the cost. The next thing you'll need t learn is when to use with grade of sandpaper as you're taking the surface down.
Good Luck
/// MODS
Old 01-06-2013, 10:59 AM   #14
tylermaslanik
My Ride: 3 Pedal 323Ci
Good Luck
+1...Not too hard. Just lots of work.
tylermaslanik is offline   Reply With Quote
Old 01-06-2013, 11:06 AM   #15
Blizare
My Ride: 2001 330xi
Don't spraybomb it.
Blizare is offline   Reply With Quote
Old 01-06-2013, 12:48 PM   #16
WDE46
My Ride: '13 128i, '04 330Ci
Good Luck
There is no way you need to work up from 100 grit paper, especially on a small part like this. You also don't need a ridiculous buffer setup. A part as small as this could easily be polished to perfection my hand. You're exaggerating the difficulty by a long shot.
Old 01-06-2013, 01:08 PM   #17
TitaniumCranium
/// Limitless
Really? It completely depends on what you consider an acceptable paint job. I'll admit I have OCD to a fault and have accepted that I am a perfectionist living in an imperfect world.
If you screw the clear coat up and don't get a mirror finish (glassing the paint) you either take it back down and start over from 100-320,prime, finish sand 400-600 and repaint until you get it right, or you wet sand it out with 600-2000 grit and buff it out. Yes you can hand polish but you cannot get a mirror finish by hand even on a part that small. Can you get close, yes - but a buffer (a real buffer not a porter cable) can do what no hand can do. No painter makes money on buffing, but few armatures get away with laying glass. That's the difference between a paint shop that does reputable work and work that's just, "hmmm, yeah it looks ok".
/// MODS
Old 01-08-2013, 07:55 PM   #18
erich330ci
My Ride: 2004 330ci
Thanks, All, but I'm really just looking for product advice. Bavarian Autosport sells it. PaintScratch. Automotive Touchup. I'm weighing these possible options versus having a shop mix up a bottle for me. Any thoughts?
Thanks!
Eric H.
Old 01-08-2013, 09:18 PM   #19
wildirish317
Depends on what you want. $100 is not much to pay for a spoiler paint job, if the final result is what you are seeking. You could spend as much or more by trying it yourself, based on the knowledge posted on this thread. If you don't have experience with spray paint, and want a good looking spoiler at the lowest price, pay to have it done. If you want to learn how to use a spray can, because you may want to paint other things (on your car or in your house), then try a can from BavAuto. Education costs before it pays off.
Old 01-09-2013, 12:17 AM   #20
tock172
My Ride: '12 135i DCT
paintscratch.com
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
