Australia
Old 01-07-2013, 02:41 AM   #1
M3N7AL
My Ride: E46 M3
Service Tips?
Getting my 90 000km Service done tomorrow.
It's not an inspection I or II.
It's pretty much an in between service. I do my servicing every 10k's.
I've decided while it's there to do everything and freshen it up.
Does anyone have any tips on what else to do and if i've missed something.
This is what i'll be doing:
*Change Oil, Filter etc
*Check if car is running at full potential
*Full inspection (susp/engine/tranny/diff etc)
*Check engine codes
*Check tranny and diff mounts
*Valve adjustment?
*Tranny fluid/service
*Diff fluid/service
*Compression test
*Check subframe for cracks (even though its a convertible)
M3N7AL is offline   Reply With Quote
Old 01-07-2013, 02:49 AM   #2
DeclanM3
My Ride: 332Ci
Sounds pretty comprehensive. Brake fluid and coolant flush whilst you're at it depending on when they were last done.
DeclanM3 is offline   Reply With Quote
Old 01-07-2013, 02:53 AM   #3
M3N7AL
My Ride: E46 M3
Awesome, i'll make a note of that. Anything else... ? What's involved in a SMG service?
Old 01-07-2013, 03:18 AM   #4
DeclanM3
My Ride: 332Ci
DSC off, S6, hold the shifter forwards, put your foot down on the throttle (the quicker the better), release shifter, counter-steer.
Old 01-07-2013, 03:23 AM   #5
M3N7AL
My Ride: E46 M3
HAHAHAHAHAHA!
Is an SMG Service just a transmission fluid drain/change?
Old 01-07-2013, 03:24 AM   #6
DeclanM3
My Ride: 332Ci
HAHAHAHAHAHA!
I believe so.
Old 01-07-2013, 03:25 AM   #7
M3N7AL
My Ride: E46 M3
Awesome.. If anyone else has any other tips or things to look out for/check it'd be great to hear them.
Some people have been mentioning Fuel Filter change..
Old 01-07-2013, 03:32 AM   #8
DeclanM3
My Ride: 332Ci
You can go nuts if you really want to. I did the fuel filter in my 325 at 140,000kms and it was still perfect but because I did it myself it was fun (besides fuel in my eye) and only cost ~$100. Are you DIY'ing or paying to have someone do all the work for you?
If you are DIY'ing then you could do things like belts, pulleys, fuel filter and a couple of other things if you really wanted to as the parts are relatively cheap. Probably under $300 for everything I just mentioned.
If you're paying someone else to do it for you then it might not be worth it. You'll probably get stung 2 hours labour for a fuel filter alone so there's no point if it's in perfect condition.
Old 01-07-2013, 03:34 AM   #9
M3N7AL
My Ride: E46 M3
A workshop is doing it for me, not charging me full price, mate's rates. But if what you're saying is true then i'll prob leave it.
Any other critical/important things i need to do that you've done?
Old 01-07-2013, 03:38 AM   #10
Alpine
My Ride: 2002 E46 BMW 330Ci
How can you tell if a fuel filter is due for changing though?
Alpine is offline   Reply With Quote
Old 01-07-2013, 05:30 AM   #11
[SeN]
My Ride: 2002 M3 Imola Red
Hey man, might as well change the Power Steering fluid whilst ur at it changing the other fluids. It's easy n cheap to do and is quite often overlooked. Use ATF fluid.
I'd also change the Vanos filter as well but its a easy DIY job.
Get ur Valve clearances checked if you haven't done Inspection II, other than that everything else u listed or mentioned is spot on.
Sent from my GT-I9305T using Bimmer App
Bilstein PSS10 /// Vorshlag Camber Plates /// Turner Motorsports RSM /// Rogue Engineering Octane SSK w. ZHP gear knob /// Dice MediaBridge 1500
[SeN] is offline   Reply With Quote
Old 01-07-2013, 05:38 AM   #12
M3N7AL
My Ride: E46 M3
Is checking valve clearances the same as a valve adjustment?
Old 01-07-2013, 06:00 AM   #13
DeclanM3
My Ride: 332Ci
Pretty sure checking the clearances is the process to check whether an adjustment is required. Could be wrong, I'm sure someone will confirm / deny.
Old 01-07-2013, 06:04 AM   #14
M3N7AL
My Ride: E46 M3
Ok sweet. I'll just tell them tomorrow to see if it needs a valve adjustment.
Old 01-07-2013, 10:17 AM   #15
kook
My Ride: F20 125i
Same thing. If they check your clearances and they're out, they willl hopefully adjust them! As said previously, definitiely check your vanos filter, simple 5 min DIY...
2011 Passat V6 Highline Wagon
1975 Kombi
SOLD : 2013 F20 125i M-Sport
SOLD : 2005 Le Mans Blue M3
kook is offline   Reply With Quote
Old 01-07-2013, 11:34 AM   #16
M3N7AL
My Ride: E46 M3
Ok thanks.
Old 01-07-2013, 07:07 PM   #17
kook
My Ride: F20 125i
This kit at ECS includes O-rings as well, $21. I change it out every service, I have vanos paranoia Already had my vanos intake bolts swapped over to the newer style ones.
http://www.ecstuning.com/BMW-E46-M3-...ter/ES1892454/
1975 Kombi
Old 01-07-2013, 08:01 PM   #18
M3N7AL
My Ride: E46 M3
How much does it cost to have the Vanos bolts replaced to new ones?
Old 01-07-2013, 08:36 PM   #19
kook
My Ride: F20 125i
I had a stack of other work done at the time, so not sure. Make sure you get the new bolts, BMW have changed them from what was installed originally. These are the ones
http://www.ecstuning.com/BMW-E46-M3-...05536/ES16140/
Massive DIY write up here on it, but unless you are mechanically minded, its a dealer job. This poor poster had bothe exhaust hub tabs sheared off as well... My tabs were both good fortunately
http://www.m3forum.net/m3forum/showthread.php?t=411224
1975 Kombi
Old 01-07-2013, 09:37 PM   #20
M3N7AL
My Ride: E46 M3
I was just told today that the tranny oil doesnt need changing as it's long life oil... Hmmm, the mechanic i spoke to at my mates workshop said not to change the SMG oil.
He also told me not to change the Vanos filter as that's something that is more for E36's. And he said the Valves don't need adjustment.
Can someone help?
