Australia
Old 01-07-2013, 10:17 PM   #21
kook
My Ride: F20 125i
From what you say your mech thinks a vanos filter like this can be healthy for your engine. This is an E46 M3 vanos filter...
http://i373.photobucket.com/albums/o...gno/chris6.jpg
The vanos filter you can change yourself, takes literally a few minutes. Do the O-rings as well, I linked to the kit above
Thread here about valve adjustment, once again you decide after reading that. When were the valves last checked?
http://www.e46fanatics.com/forum/sho...php?p=12710667
So is your mech saying never to change the tranny/SMG oil???
Some people are happy with their mechs, maybe I'm way too cautious, but the guy who works on my car (also a member of our local BM club and good bloke) is a certified BMW Master Tech at a BMW dealer. I dont let anyone else touch it. Sure, the labour rates are high, but I make up for it by buying all parts beforehand from OS...
Remember, you have a performance vehicle, that for a naturally aspirated engine had one of the highest HP output for a production car ever. Treat it as such...
2011 Passat V6 Highline Wagon
1975 Kombi
SOLD : 2013 F20 125i M-Sport
SOLD : 2005 Le Mans Blue M3
kook is offline   Reply With Quote
Old 01-07-2013, 10:29 PM   #22
M3N7AL
My Ride: E46 M3
Ok sweet.
I'll do the vanos filter myself.
What tranny fluid is the best for the E46 M3 and what's the best diff fluid for no noise etc
What does BMW use and would that be the way to go?
M3N7AL is offline   Reply With Quote
Old 01-07-2013, 10:46 PM   #23
[SeN]
My Ride: 2002 M3 Imola Red
Originally Posted by kook View Post
This kit at ECS includes O-rings as well, $21. I change it out every service, I have vanos paranoia Already had my vanos intake bolts swapped over to the newer style ones.
http://www.ecstuning.com/BMW-E46-M3-...ter/ES1892454/
Me too man. Swapped them out and turns out mine where fine anyway but now its one less thing for me to worry about.
Originally Posted by M3N7AL View Post
Ok sweet.
Tranny: Can't get oem now but Pentosin MTF2 is the closest to oem you can get. Im currently using Amsoil MTF myself.
Diff: Castrol SAF-XJ +FM is the best for diff.
Link for you: http://www.turnermotorsport.com/p-21...or-e46-m3.aspx
Bilstein PSS10 /// Vorshlag Camber Plates /// Turner Motorsports RSM /// Rogue Engineering Octane SSK w. ZHP gear knob /// Dice MediaBridge 1500
[SeN] is offline   Reply With Quote
Old 01-07-2013, 11:52 PM   #24
LSM3
My Ride: E46 ///M3
I was just told today that the tranny oil doesnt need changing as it's long life oil... Hmmm, the mechanic i spoke to at my mates workshop said not to change the SMG oil.
He also told me not to change the Vanos filter as that's something that is more for E36's. And he said the Valves don't need adjustment.
Can someone help?
He's right insofar as you don't HAVE TO change it, you don't have to do interim services either, but it helps maintain your asset as best as possible. So I would be thanking him for his input, but insisting he do what he's told.
___________________________________________
2006 CS M3 | ESS Tune : CSL SMG tune : Eisenmann Race : Eibach : Tekarbon
LSM3 is offline   Reply With Quote
Old 01-08-2013, 12:00 AM   #25
DeclanM3
My Ride: 332Ci
I'd be taking it to someone else who can appreciate that you want extra maintenance performed. I reckon they'd be much more likely to take care of it.
As for vanos filters that's a bit worrying that he doesn't think they need doing based on what I've read.
DeclanM3 is offline   Reply With Quote
Old 01-08-2013, 12:49 AM   #26
M3N7AL
My Ride: E46 M3
What are the symptoms of an M3 that needs a valve adjustment?
Old 01-08-2013, 01:18 AM   #27
LSM3
My Ride: E46 ///M3
You hear a loud ticking sound when you hold a constant amount of revs.
In my previous M, when i was cruising at 60-70kmh with the window down, i could just hear this loud ticking. That was at about 140,000km or so.
Old 01-08-2013, 01:19 AM   #28
M3N7AL
My Ride: E46 M3
Yeah i've got that. Not loud though.
With the window down cruising along in 4th, 5th etc. I can hear ticking as i'm driving.
What parts do i need to buy for a valve adjustment? Also what's the usual rate to have it done?
Old 01-08-2013, 01:21 AM   #29
LSM3
My Ride: E46 ///M3
Yours should be within tolerance because it hasn't done that many kays, but its always good to have it checked.
Also, its a relatively large job, i had to leave my car with my mechanic for two days. The result was no ticking at constant revs, but no change in performance - the engine was just heaps quieter.
Old 01-08-2013, 01:23 AM   #30
M3N7AL
My Ride: E46 M3
What did they slog you for it?
And what happens if i don't get it done?
Old 01-08-2013, 01:46 AM   #31
LSM3
My Ride: E46 ///M3
Parts are fsck all, its the labour component that makes it an expensive exercise. Lots of poontangers in the US do it themselves... But it just seems like something you shouldn't attempt unless you know you can finish it.
Old 01-08-2013, 01:47 AM   #32
LSM3
My Ride: E46 ///M3
I think i paid around $1K from memory - maybe a little less
Old 01-08-2013, 01:52 AM   #33
M3N7AL
My Ride: E46 M3
Wow $1k!
What parts are needed tho so i can source them.
What happens if i don't do the adjustment?
Old 01-08-2013, 02:03 AM   #34
LSM3
My Ride: E46 ///M3
Concening parts, you need a shim kit and anything else i have no idea about. Check M3F for valve adjustment threads, there is heaps of info on the subject.
If you don't do it? I am unsure what the side effects are apart from the ticking noise. Given that your car only has 90,000km you have a couple of years before you'd need to do anything imo.
Old 01-08-2013, 04:19 PM   #35
sprintman
My Ride: Ex 325CI owner
Originally Posted by Alpine View Post
How can you tell if a fuel filter is due for changing though?
Change it every 50,000 kms. you'll be glad you did.
sprintman is offline   Reply With Quote
Old 01-08-2013, 05:13 PM   #36
DeclanM3
My Ride: 332Ci
How so? I noticed no differences when I changed mine.
Old 01-08-2013, 05:22 PM   #37
forzamilan10
My Ride: '04 325Ci Sport
@Kook, hate to go off topic, but your M3 is absolutely gorgeous.. Le Mans Blue *drool* - do you have any photos or have you made a thread? I'm being lazy.
'04 325Ci + MYSTIC BLUE + EISENMANN RACE EXHAUST & MID-PIPE
forzamilan10 is offline   Reply With Quote
Old 01-08-2013, 08:03 PM   #38
Ballistic325
My Ride: slow and steady
I noticed a big difference when I last changed mine.
Less noise from the fuel pump, smoother idle, better acceleration.
The old filter was filthy and likely clogged on the inside.
Sent from my V9 using Bimmer App
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 01-08-2013, 08:37 PM   #39
kook
My Ride: F20 125i
Thanks, its a great shade of blue! I stuck some pics over in the showroom thread...
http://forum.e46fanatics.com/showpos...postcount=4320
1975 Kombi
Old 01-08-2013, 09:25 PM   #40
M3N7AL
My Ride: E46 M3
Which filter are you talking about?
Ok i think since it's only done 90 000k's and it's got Inspection II coming up at 100 000k's i'm only going to do this:
Engine Oil & Filter
Fuel Filter
Coolant Flush (only because it's a little bit dirty)
Check other fluid levels, brake/power steering etc
I'll order in a Vanos Filter and other bits from Turner Motorsports for the Inspection II once it hits 100 000k's. That way once the next service comes along i'll do a valve adjustment and stuff too.
How does that sound?
