#21 | |
Weagle Weagle
Scenario 1: The square yellow piece is in the upper range of it's size tolerence. the flap's square hole is on the lower range of it's size tolerance. This scenario creates a tight fit which may prevent the flap from ever jiggling and wearing down the inner surface of the flap/outer surface of the yellow arm Scenario 2: The square yellow piece is in the lower range of it's size tolerance (bordering on too small) The flap's square hole is in the higer range of it's size tolerance (almost too big) This scenario creates a situation in which there may be a small amount of play b/w the yellow piece and the flap, and the parts experience increased wear. The play will increase over time which will continue to increase the wear. It could also come down to driving habits, but I think the above is possible. Last edited by WDE46; 01-08-2013 at 12:28 PM. |
#22 | |
2002 BMW 330i
![]() Jet Black 2002 BMW 330i Tan Leather Interior Loaded DonaldE |
#23 | |
2002 BMW 330i
#24 | |
Weagle Weagle
#25 | |
My Ride: '06 330CiC, '03 M5
![]() Quote:
The vacuum diaphragm and the solenoid do fail, the vacuum diaphragm fails far more often than the solenoid. The vacuum diaphragm is rubber and in the under hood heat and gasoline/oil vapor rich environment, the vacuum diaphragm is likely to fail somewhere after the 8 year mark give or take. As for moving the parts once installed, not sure this is so easy with the red Loctite that I think is provided. This is kind of like the situation where everyone is interested in replacing the $30 worth of intake boots on the car with over $100 of silicon boots. Look at it this way, replace your intake boots every 6 years, likely you will not be replacing a 2nd set of boots, but if you do, you can check your DISA, replace the O-ring, clean the ICV sort the CCV and all the other vacuum lines by year 12, I doubt many of us will be driving our E46 by they time they turn 18 years old?
Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501 Temp Info - http://forum.e46fanatics.com/showthread.php?t=964491 Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619 E46/E39 GM5 Door Lock Info - www.bmwgm5.com Lower hose fan switch O-ring - BMW #13621743299 |
#26 | |
Weagle Weagle
#27 |
Grand Superpatriot
Like I said, you're new here. Sound advice is what I do. Not saying your method was necessarily a bad one, but it isn't good, either. Results are mixed at best. Safe bet is to just replace it. Listen to JFOJ
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#28 |
No matter if Donald's new or not. He's sharing his first hand experience on the G.A.S. DISA kit with all of us. That's the important part here. We'll see if the remaining portion (vacuum diaphragm) of his original DISA will hold up from this point on. I replaced my DISA with a brand new unit last year. I had considered getting the same G.A.S. V.R.K. however, at the time I just didn't wanted to mess with retrofitting anything. Plug & play - less than 10 minutes to get everything re-assembled. |
#29 | |
Grand Superpatriot
And are you sure this kit is new? I've been hearing about it myself and did you actually read what JFOJ said about the internals (which are untouched by this "rebuild"?) Seems again, people are avoiding the safe bet to save a few bucks. If this kit is brand spanking new, we have no long-term evidence of its performance so any early adopters are more or less guinea pigs. (More power to you, but I don't like to experiment)
#30 |
Weagle Weagle
I think it's pretty clear that this kit works perfectly. There is no way the stock setup is superior in this case. The only thing you can call into question after installing the kit is the vacuum diaphragm. That's a perfectly valid concern. JFOJ did have a good point though. If you just replace the whole thing, it'll be ALL good for the next 8 years, while a repair kit might last 1-2 before the diaphragm fails (if it fails that quickly).
#31 | |
#32 | |
#33 | |
The big issue is if the DISA pin fails, it'll blow the motor. Very similar to the S54 Vanos hub issues in that regard.
#34 | ||
Grand Superpatriot
![]() http://www.e46fanatics.com/forum/sho...2&postcount=22 http://forum.e46fanatics.com/showpos...2&postcount=63 As I always say, your car!!
#35 | |
Grand Superpatriot
Sorry but this post is so good I must quote it in its entirety. It deserves its own post!
#36 |
Jb weld on the shaft and inside the flap and a $5 o-ring fixes the DISA flap flapping and the vac leaks As long as the pin is good no worries. I did it when the money was tight to keep me going. I haven't found a reason to get a new one yet with 50K on one I did. I've checked it few times all is well.
OK here comes the flames
#37 | ||
#38 | |
Grand Superpatriot
What's this deficiency you speak of? In that light, every other part on our cars have a "deficiency."
#39 | |
Weagle Weagle
The post by JFOJ is good reasoning. Well said. Thinking about it now I probably won't get the repair kit as it'll be many years until a new one wears out.
#40 | |
Grand Superpatriot
![]() Some people may have certain driving habits or conditions which may speed up failure. Not sure?
