Old 01-07-2013, 06:16 PM   #1
mrbill
My Ride: M6, 525i
Xenon Bulb Replacement
Hello- I have an 04 330i (sedan). I can see the headlight projectors so I believe this automagically means I have Xenons (low beams). I can hardly see at night. There's definitely light... its just dim. From what I've read here, this usually means bulbs are going. So as a first step, I ordered Philips D2S Xenon HID Headlight Bulbs part number: 85122C1 - The 'C1' threw me so I called Philips and they said its the same as the 85122+, just updated part number.
2 questions:
- Did I order the right bulb (I'm pretty sure I did)
- Could anything else be causing this? I had to pickup a part at the dealer and they suggested the ballasts as well, but I sort of find that hard to believe.
Thougths? Thanks!
mrbill is offline   Reply With Quote
Old 01-07-2013, 08:27 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Yes, those are the correct bulbs.
Install the bulbs (DO NOT TOUCH THE GLASS) and make sure to level the lights properly using the black wheels on top of the headlight. Then report back. Pics always help.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 01-07-2013, 08:56 PM   #3
mrbill
My Ride: M6, 525i
Hey- Thanks for the info. I' ll post before and after shots. Never re- leveled so ill look for the article on that.
thx!
Old 01-07-2013, 08:59 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
Just park on a flat surface with a nice clean wall ahead of you and adjust them. Check out my vid to see what it should look like afterwards
Look at the first few seconds of this one
Old 01-07-2013, 09:09 PM   #5
mrbill
My Ride: M6, 525i
i forgot to mention i have self leveling. totally spaced.
thx!
Old 01-09-2013, 01:34 AM   #6
mrbill
My Ride: M6, 525i
Is it me or are the low beam bulb boots\covers hard as heck to get on and off? I just did the driver side and wound up having to loosen and pop out the headlight unit. Is the best way to do this involve removing the entire headlight unit? I have a 2004 330i with self leveling lights.
thx
Old 01-09-2013, 10:18 AM   #7
mrbill
My Ride: M6, 525i
Hello Again- Ok, I have an image to share. Changed the drivers side last night- Wow! I'm accustomed to older BMWs... lots of plastic and things are tough to access in this car. But have to admit, the engineering is superb!
Anyway, after wrangling the boots for about 45 min, I have the drivers side working. Wanted to share what it looks like and get your opinion on the light spread. Enclosed is a picture. Its MUCH brighter than the passenger side. But are the 'hot spots' normal? Let me know what you think.
Thanks for all the help. I'm an older BMW guy and working to get up to speed on the complexity of these new machines .
Name:	Drive Side Changed.JPG
Old 01-09-2013, 10:20 AM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
mmmm, those hot spots don't seem correct. I'll take a pic of my output tonight after work
Old 01-09-2013, 11:00 AM   #9
mrbill
My Ride: M6, 525i
Ya, didn't seem normal to me either. Thanks for taking a look.
Old 01-09-2013, 12:11 PM   #10
Rudy540
My Ride: E46
My dads 325i lights also are extremely weak for some reason, I tried a new hid bulb but not much difference, did u change ballast?
Rudy540 is offline   Reply With Quote
Old 01-09-2013, 01:29 PM   #11
mrbill
My Ride: M6, 525i
I only changed 1 bulb and already notice a huge difference. Haven't touched the ballasts.
Old 01-09-2013, 11:00 PM   #12
mrbill
My Ride: M6, 525i
Quick update
Removing the entire headlight assembly is clearly the way to go when changing the bulbs on a 2004 self leveling hid system. Far easier. Now that i've seen how the bulb is supposed to align within the sockets, i now know the driver side bulb is incorrectly installed. The passenger light pattern is spot on and bright. Ill fix the drivers tomorrow and upload picts.
Old 01-09-2013, 11:02 PM   #13
Solidjake
Zero. Leaks.
Solidjake's Avatar
yea, I figured the bulb was not seated properly. Post some pics when both are installed.
Old 01-16-2013, 03:49 PM   #14
mrbill
My Ride: M6, 525i
Hello- Ok, finally have before and after photos. Big difference. BTW- As I mentioned before, its far far easier to change the bulbs via removing the headlight units. Only takes about 5min per side this way.
All I did was replace the factory bulbs with new factory bulbs. Nothing upgraded. Much better.
ID:	486342   Click image for larger version
Old 09-14-2013, 11:10 PM   #15
Leanwidit
My Ride: E46
Having the same fkn problem!
Thanks guys, i now have a solution!
Btw, does anybody knoe which bulb i should get for my 325i 2004 xenon? Any help will be appreciated.. ^___^
Leanwidit is offline   Reply With Quote
