Old 01-07-2013, 06:31 PM   #1
TheCleanist
My Ride: 325cic
Exclamation Eagle Eye Tail Light Problem
Hello,
So I've had my eagle eye LED tail lights for about a year and a half now and have never encountered a problem with them until recently. It is hard to explain but I will try my best... The problem is that sometimes both tail lights fully work and sometimes one side misfunctions. By this I mean that the Driver side tail lights up on full power and the passenger side will be barely on. And once i press the brake, the passenger side completely goes off. I have asked around and no one can tell me what the issue is or how to fix it. I have heard it may be the transformer or the ground wire but i have no idea what to do with them. My one year insurance on the lights is over so please helppppppppppp!
ID:	485058   Click image for larger version
TheCleanist is offline   Reply With Quote
Old 01-07-2013, 06:51 PM   #2
shovelit
My Ride: 03 325xi and 04 330x
Not sure what "eagle eye" lights are, but That problem is usually caused by a bulb inserted backward or a ground problem.
shovelit is offline   Reply With Quote
Old 01-07-2013, 06:54 PM   #3
TheCleanist
My Ride: 325cic
Eagle eye is the brand of LEDs. Do you know if there is something I can do with the ground wire?
Old 01-07-2013, 08:30 PM   #4
328ci906
My Ride: 2003 M3
You can't invert the bulb because they are LED's. Mine did something similar earlier this year, it turned out to be a bad resistor or capacitor on the wire harness for the tail-light. I swapped it out with a new one and it's been good ever since.
-2000 E46 328i
-2006 E60 M5
328ci906 is offline   Reply With Quote
Old 01-07-2013, 08:42 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Could be any part of the wiring that went bad or the resistors/capacitors included.
You have a coupe, buy OEM tail lights
Old 01-07-2013, 08:47 PM   #6
TheCleanist
My Ride: 325cic
Thanks for the help guys, I think I'm just going look for a new passenger side light, if not then buy a new set :/
Old 01-07-2013, 09:29 PM   #7
TallSkinnyMatt
My Ride: E92 M3 ZCP
This. I've never had a problem with my OEM tails!
TallSkinnyMatt is offline   Reply With Quote
convertible, e46, eagle eye, led, tail lights
